- 28 Sep 2014
- Scotland
No need in addition file to run the benchmark.What else is needed in addition to your file to run the benchmark?
Might give it a whirl tomorrow![]()
Just click BulkLoadDemo.exe to run the benchmark that will do default GPU decompression.
If you want to see CPU decompression instead, click on BulkLoadDemo folder and right click to open in Terminal and type in ./BulkLoadDemo -gpu-decompression 0 and you will see benchmark run at 100% CPU usage doing CPU decompression.
Edit:
Are you DirectStorage ready?
What else is needed in addition to your file to run the benchmark? Might give it a whirl tomorrow :) No need in addition file to run the benchmark. Just click BulkLoadDemo.exe to run the benchmark that will do default GPU decompression. If you want to see CPU decompression instead, click on...
