- 27 Jan 2009
- Oxfordshire
I thought this might be the case but aside from filling the sink quicker than it can drain if using just cold on full blast it’s not splashing around, but good shout on using the isolators to tune it down if needed.You might find you need to reduce your flow. I fitting a waterfall one to my downstairs toilet sink (which is narrow), and as the water comes out the front rather than underneath there is a bit more splashing. There's isolators on the hot and cold though so I've reduced it that way.
