- 30 Nov 2011
GN have cables from end users that failed - they all show marks that indicate the connector was bent whilst 4mm not plugged in. How much proof do you want?which is unproven
i see ...About 12 hours too late mate
I think this issue was always there on even the 8 pin PCIE connectors and maybe people don't plug them in properly but since it has such a ridiculously high safety margin, if you don't connect them all the way, the pins which do make contact can handle all the current. This connector does not have that safety margin.Yep and as I thought the longer this went on it was user error, In all honesty I'm glad GN did this research and video to call out all other so called experts because as a user like myself when you hear techtubers like Igor and Jay just guessing and blaming Nvidia a lot of people would listen when the fact is I've seen some pics of some of these on this Reddit and you can clearly see a gap between the plug base and the connector tip.
We know no user likes to be blamed for the issue or because it happened to them but it wouldn't surprise me in the slightest that the users that it has happened to they have tried to cover up their mistake or oversight by trying not to show that it wasn't connected properly.
It's not a dig at inexperienced users per say and the connector is stiff I know that from first hand experience but come on if you're really not that competent in connecting a cable together then you really shouldn't be going near this sort of equipment.
Look we all make mistakes I have in the past but experience has always taught make sure everything is plugged and seated to the best of your knowledge, There should not be any gap in any connector on the PC, You may get away with a PWM fan header not connected properly because of the low power but you're not going to get away with that at these sort of wattages.
Only 0.1% failed and that's the worst case scenario. Realistically it was 0.05%. If this was a beta test, I don't blame them for pushing out the final product. It would be impossible to materially improve the failure rate. 99.9% of users are plugging it in correctly.Any issues you can point out from previous halo product releases?
So paying such a premium I should be expecting to be a beta tester?
Realistically it was 0.000000.15%Only 0.1% failed and that's the worst case scenario. Realistically it was 0.05%. If this was a beta test, I don't blame them for pushing out the final product. It would be impossible to materially improve the failure rate. 99.9% of users are plugging it in correctly.
The other connectors had a safety margin to account for user error. This one does notHow do you explain how these users who are incompetent to insert a connector correctly manage to do so with at least half a dozen other connectors and probably have done so with dozens if not hundreds of connectors?
Even brand new PCIE connectors are stiff but yes I agree they did have a more audible click although I know people that have also damaged their PSU's and motherboards through not connecting the 2 pin on the 6+8 pin properly which is also a ****** design in all honesty, I've had more trouble in tight spaces ensuring that crappy 2 pin connector was in properly haha.I think this issue was always there on even the 8 pin PCIE connectors and maybe people don't plug them in properly but since it has such a ridiculously high safety margin, if you don't connect them all the way, the pins which do make contact can handle all the current. This connector does not have that safety margin.
While the Nvidia adaptor is now confirmed to not be the issue, it's still very badly made as it simply does not click on many GPUs like Zotac. Cablemod does very easily. Once you install the cablemod it actually looks very sleek in the case instead of looking at the cable kraken with 4x8pin.
Yeah, I've had loads of occasions where those god awful split 4+4 or 6+2 connectors wouldn't go in properly, they are a complete ball ache compared with this new one.Even brand new PCIE connectors are stiff but yes I agree they did have a more audible click although I know people that have also damaged their PSU's and motherboards through not connecting the 2 pin on the 6+8 pin properly which is also a ****** design in all honesty, I've had more trouble in tight spaces ensuring that crappy 2 pin connector was in properly haha.
I know they were initially like that because of older less powerful GPUs that only had 6 pins but to this day they still do not add extra cables in the boxes to support a fully moulded one piece 8 pin cable for those that need it.
Backwards compatibility issues at it's finest, I'll be honest I do prefer this new connector it's very neat although not with the bundled adaptor it's a total mess.
My Cablemod cable has finally shipped a few days ago so it will still be getting swapped out for aesthetics alone.
But yes it won't be the first time people don't connect cables properly, Even the 2 8 pin connectors at the top of the boards for the CPUs I've had trouble with because of the area they're in and on setting this Alder lake system I noticed a gap in the space like it wasn't connected properly so wasn't happy and didn't power it up for the first time until I checked it again and reseated it until I saw it was pretty much flush before powering on.
I was blind nvidia fanboy and troll for suggesting failure rate was tiny 16cards in how many hundreds of thousands sold?Realistically it was 0.000000.15%
They will all burn, wallets bro.I was blind nvidia fanboy and troll for suggesting failure rate was tiny 16cards in how many hundreds of thousands sold?
they are all going to burn they told me, couldn't possibly be people not plugging them in I must be a conspiracy theorist.
IDK how these people don't get banned from these threads when they post meme crap... yet I get banned from an NVidia thread for replying to some AMD fanboy saying atleast nvidia had a launch al AMD brought was paper plates.....
people can fit a cpu cooler. but can't plug a cable in properly? and we blame the cable ?I think it's quite clear that this general connector design is just plain poor, it really shouldn't be an issue.
did people stop buying them or somethingpeople can fit a cpu cooler. but can't plug a cable in properly? and we blame the cable ?
remember toddler toys where you push the shape through a hole?did people stop buying them or something
Maybe they have no arm power?doesnt change anything the same people still wouldn't plug it in properly
What cable are people buying from cablemod? I've tried the configuration thing on there but am lost.
