Good choice. Once you've used the zoom lens for a while you'll know what lens to buy next.Think I’m going to go with a refurbished X-T3 and XF 18-55mm f/2.8-4 R LM OIS
Both seem perfect for my budget and experience
Good shout, Wex are good.Have you tried Wex as well? They have some used X-T3 and 18-55mm bundles and I have always found items in better condition and price than MPB.
Yep. I normally cycle between MPB, WEX and London Camera Exchange oddly enough. If I'm looking for an item I'll go through all 3 for the cheapest.Good shout, Wex are good.
Fujifilm X-T3 Digital Camera with 18-55mm XF Lens - Black | Wex Photo Video
www.wexphotovideo.com
It's about the going rate for a mint example. Assuming it has all the accessories and is boxed.Mint/Boxed X-T3 at my local camera shop, £725
Personally I would try and go X-T30 if budget doesn’t allow for a 3.I’m going backwards and forwards looking at reviews for the X-T3 but initially I had a budget in mind which if I go the T3 route would put me closer to 1k
So with that in mind is the T2 a viable option and would the same lens me mentioned 18-55mm still fit, many thanks in advance
This.Personally I would try and go X-T30 if budget doesn’t allow for a 3.
It has all newer internals than the X-T2 and I think it would benefit you much better than the 2.
That said, if the slightly larger form factor is a must then 2 is a solid camera - but the 30 is better in almost every metric (it’s a baby X-T3).
Don’t get too hung up on the mark ii of the X-T30. The differences between it and the mark i are virtually indistinguishable.
There’s also one over on ebay for £479 being sold by UPG24UK who are a dedicated used camera gear seller.This.
I found a good example worth checking out https://www.lcegroup.co.uk/Used/FujiFilm-X-T30-Black-Body_356783.html
But yeah, have always found LCE a pleasure to deal with.
Thanks gents! Xmas made my preset giving to myself a bit tighter![]()
It’s Xmas I’m getting skimmed from all directions, reviews are stunning but the cost is a bit tough to swallowget the X-T3, i have one and they are very good
Link states £349? or am I missing something18-55 "opened - never used" for £279.20 here - https://www.ebay.co.uk/itm/134286912290?epid=3035204300&hash=item1f441fab22:g:9BQAAOSwr1xjTr0H&_trkparms=%26rpp_cid%3D6371251d06c1f66450ebe5ff
With the code BETTER20
Cameracentreuk are a good seller too.
BETTER20Doh! Shoot me now, ta bud, would this got the Xt30Missing the codeBETTER20
https://i.~ibb.co~/NKhxdg3/code.png
