Caporegime
 - 18 Oct 2002
Came with V018 and updated to V023. Still has minor issues.People with the 48 what firmware did yours come with and what are you running ?
In his latest video on the updated aw34 from Alienware, Linus announced that his pg42uq has burn in after 1 month of use. He didn't say what settings he uses, but he has a history of burning in his OLEDs screens. He briefly showed the burn in and it looks like it's the windows desktop background image that is burned in, so he likely leaves the screen idling on desktop
It looks like his usual thing... he is a heavy user of snap zones on his 4K displays ie his display is divided into 4 quadrants, each quadrant has some app maximized within the zone. I think the main takeaway I am coming away with is that you can use an OLED for productivity but its not going to be ideal or problem free UNLESS you are willing to invest effort and possibly changing your useage patterns. The latter could be a deal breaker for some people when it comes to their work habits.
I am still going to give the 42 OLED a chance I think (8 hours a day productivity then several hours at night for leisure) but I am going into it not without trepidation...
edit: and i should add my interest/consideration of the Samsung Neo G8 is slowly climbing...
PG48UQ is even worse, it almost feels abandoned...when the hell are Asus releasing the new firmware they said mid nov...
| G-SYNC Compatible | ASUS | PG42UQ | Yes | 42 | OLED | 3840x2160 (4K) | 48-120Hz | No | Display Port | 526.98 or newer |
On a side note, ARMS warriors are getting a huge nerf on release.Captured the image corruption that appears randomly for a split second:
It‘s always different in size and position.
I have ordered a different DP 1.4 cable...
Running in 120 HZ. Not touched the overclocking mode.
Haha, not playing WoW for any of that anymore. That takes just too much time.On a side note, ARMS warriors are getting a huge nerf on release.
I am on my PG48UQ, no issues.Are you guys using the Display Driver?
OK one week of testing completed. With 4k 10bit 60Hz on normal desktop use including video playback and 120Hz when gaming and I have not experienced my issue even once. I am quite certain it is an issue with DSC and hardware accelerated video playback (possibly with HDCP?). Not 100% sure if the problem is the display or GPU/drivers. My previous display did not support DSC so I cannot compare to that.
On Monday I will switch back to running everything on 120Hz and see how long does it take for the issue to manifest itself the first time.
Version V033 2022/11/28
1.Optimized firmware update tool.
2.Optimizing ConsoleHDR.
3.Improve the power indicator issue.
ROG Swift OLED PG42UQ
42-inch 4K (3840 x 2160), OLED, 138 Hz (OC), 0.1 ms (GTG), G-SYNC® compatible, anti-glare Micro-texture coating, 98% DCI-P3, true 10-bit, HDMI® 2.1, DisplayPort™ 1.4rog.asus.com
