- 2 Feb 2018
- Exeter
1440p is where you see the biggest difference, especially the min CPU FPS. 400pts difference between each Clock/Timings. 3733 C14 is the fastest here.
Not much difference between 3200 C14 and 3600 C16 in the other tests, but there is an uplift with 3733 C14, especially the CPU mins.
1080p is a strange one, especially with the 4090.
Max CPU FPS is margain of error at this res, as Windows could start a task at any given moment during the benchmark, and results can differ due to the main load on the CPU, so any extra process would have a negative impact on the results.
What would have been more accurate, but very time consuming, is running 3 test of each, and take the mean of each one. That would be 27 tests to run...
