- 28 May 2007
These GPU's are on TSMC's most expensive node and they are large, the coolers are expensive, the PCB's are expensive, they are expensive.
You want more than 40 FPS RT is Cyberpunk? That's expensive.
This is not the first time Nvidia have made fat expensive GPU's and over saturated games with a feature deliberately to make you think you need it.
While i agree that the 4nm TSMC process will be expensive the actual gpu itself is not that large at 378.6 mm² and is probably the smallest £1200 gpu chip ever. The die size alone tell us it's a mid high chip as it's way smaller than usual high end chips.
