Not really don't think it's big enough. You can get higher capacity with lower running costs so seems a poor choice.Was it quiet and did the job though? Put it on mm![]()
Gets good user reviews and a good review on Which? so I’ll give it a crack. From what I understand compressors are more energy efficient but are generally noisier.Not really don't think it's big enough. You can get higher capacity with lower running costs so seems a poor choice.
Having use both, the main noise is air from the fan tbh. A compressor one will make no more noise than a fridge so it's not intrusive unless you want to go to sleep with it on imoGets good user reviews and a good review on Which? so I’ll give it a crack. From what I understand compressors are more energy efficient but are generally noisier.
If you're willing to spend money running a dehumidifier, why not just spend that money running the heating instead? Plus there's the one-off payment in buying a dehumidifier, which you might not actually need.Having dropped the heating lower we now have more problems with condensation (1930's 3bed detached) especially when drying washing.
I think I'll try a desiccant dehumidifier.
Any deals or recommendations, especially with black Friday coming up.
Thanks.
What am I trying to sell?You're not a very good salesman are you?![]()
Not seen those before I was about ready to get the Ebac 3850e but the 25L Meaco Arete looks good. Need to see is power consumption.I managed to pick up a 20l Meaco Arete from Argos last week and so far I'm really pleased with it. It's replacing a 20l one I picked up from Aldi a good few years back. The extraction rate of the Meaco seems to be a lot better, whilst drawing just over half the power as the old one![]()
We have turned up the heating a bit but I think we would have to have the heating on for much longer and at a higher temperature to get rid of the condensation.If you're willing to spend money running a dehumidifier, why not just spend that money running the heating instead? Plus there's the one-off payment in buying a dehumidifier, which you might not actually need.
Worst days are when we have washing to dry so I'm hoping that the dehumidifier will help with that and we won't need to run it for prolonged periods.
I don't really mind the house being a bit colder, but cold and damp is awful and I'm worried about mould.
What was your trick to get one cos they are out of stock everywhere?
Would this be any good for a 2 bed semi?
Thanks for that. Just done a bit more looking around and come across this"uses less energy than most dehumidifiers".
Spec doesn't list the energy use or decibel level.
Other models up the range seem to use more power than comparable models like Ebac or Meaco.
Rant time - for such a simple product there is some right tat out there. Why is it so hard to make a good dehumidifier suitable for domestic use.
MeacoDry ABC 10L Dehumidifier
A small, quiet, and low-energy 10L MeacoDry ABC dehumidifier. Ideal for flats, small homes and bedrooms to control condensation and maintain healthy humidity.www.meaco.com
where, in house, are you running it then ? I mean I would be opening kitchen window, maybe running ventilator, and keeping door closed whilst cooking, similarly for bathroom showering.How can the unit be pulling 3 litres a day yet the absolute moisture content in the house didn't change?
One answer is we were putting in 3 litres a day, from cooking, breathing, washing, showering etc.
Yet when I stopped using the device (although I missed a few days of readings), the absolute humidity hasn't gone up, down in fact.
We have noticed some condensation coming back onto the windows in the mornings again, which seemed to go away when we were using the dehumidifier. But that is anecdotal and isn't supported by the absolute humidity data above.
