That’s not what I see, performance definitely goes down once you either reduce voltage or power limit at 4K max settings. The card is definitely pushed beyond’s it’s efficiency sweet spot. I’m fine with losing 5-10% though for the reduced power draw. I don’t use FG or DLSS either.Well if you read the article you'd know that you can also do a 950mV undervolt which gets you full performance and brings power draw down to 280w
