you put on CH jut for the room you were in I guess ? how powerful is the boiler 30Kw .. so it was on for half the time (ignoring losses),I put on the CH for 2 hours, it hit a peak room temp of 16.4C towards the end but most of the period was lower than 15C (ambient temp of 12C), really struggled to get the temp up, in those 2 hours it consumed an extra 31.2KwH according to smart meter. So a cost of around £3.10 rounded down a bit. (10.24p KwH)
I then put portable heater on and adjusted it to hit 16C, not only did it get it there very quickly, it was also blowing the heat at me so I felt it much more, it used up around 1.4 KwH extra for those 2 hours. At a estimated cost of 46 pence. (33p KwH)
in the absence of having newer PITV valves, I'm thinking I need to relax radiator lock shield turn in few rooms being heated to increase flow rate.
IR heaters look an interesting option - I need to ask what 500W model guy, in similar Home thread used.
But I do appreciate you at least recognised I talking about my specific circumstances of only wanting to heat myself up, not my entire property. When I brought this up elsewhere, I felt I was talking to a wall as people were acting as if I was trying to say using portable heaters is a replacement to heat an entire house, when I never said that.
