What are people using as a HR monitor? Ideally looking for a cheap plug and play.
Anything ANT+ or BT.
I've always used Wahoo TICKR's but only as the first one I had lived forever (2014-2022!), so I just replaced it with the current generation one. Had a few stability issues and stuff with it, but it seems to have settled down now. Seemed to go through batteries quite rapidly (even now seems to still be active sometimes when I'm not wearing it overnight and put it on) but now it's got reliable am thinking a bad batch of batteries. I'm back on bulk bought Panasonics' from Amazon after trying cheaper EverReady and then some Duracells.
well not quite! Weren't you looking at getting one too? Did you get it?
I think they are great but the behaviours it highlights I don't really intend to change. I felt that how I was feeling often didn't correlate to how the whoop told me I should be feeling. The idea of it is you go hard on good days and take it easy on bad ones but unless you are looking for absolute peak performance then it doesn't really matter. Was good to help me point out how bad alcohol effects your body's response and now even after 1 glass of wine I can actually feel my HR rising. It's interesting and a good learning experience and would be great if you took it more seriously. It also started giving me false readings - it was detecting me at or above 150bpm when I was washing pans or cooking dinner pretty much once per week. Tech support weren't much help.
I'm on Whoop but have not noticed much correlation between it and my alcohol consumption... But I'm not changing that and generally drinking same/similar amounts at the same times each week... While also riding much the same things/intensitites and such at the same times each week... So the patterns are always the same!
But also not going to change either... Alcohol has generally become my 'reward' from working hard, but I also have to generally ride hard for it too. So Thursdays after a TTT - beer, maybe 2. Friday no riding, beer. Saturday usually big ride, beer. Sunday sometimes a long ride if I missed saturday, usually have a beer if I've ridden!
Having had 2 months off… well I’m a complete potato now!
Zero kick in the legs, just grit teeth and do my best dieseling in C grade now. Also I am riding new shoes which need a bit of adjustment/breaking in, thought time to change as my others had fallen apart but a new pair is never the same as the previous.
After 2 months off your feet should have 'forgotten' about your old shoes! Unless you where still wearing them as slippers?!
I've found on Zwift/indoors I generally ride with my shoes looser. If I don't I tend to get uncomfortable. If they're too tight can even get really painful before I notice!
What do people use as a source for Zwift?
At the moment i'm using my phone and then have a hdmi cable for it which goes to a monitor. It works ok, but there's a little lag between the phone screen and the monitor. I'm also unsure if the HDMI adaptor i'm using is cheap chinese rubbish, but every now and then it loses connection and re-connects. The official Apple one is about £40 which seems excessive.
I've had a look and see an Apple TV 4th gen seems pretty popular as a choice which can be had used around the £60 mark. I'm also unsure whether to use my work laptop connected to the monitor, it's open access at the moment, but there's talk of locking them down in future which would remove that option. Benefit of that would be the battery life, as i've noticed my phone drops battery even when plugged in, and by the time i usually get on the bike i've forgotten to keep it charged throughout the day and it's on around 25% which leaves me in a sketchy situation.
Apple TV. Without a doubt as a budget option, is pretty unbeatable. Think I'm on the 4th gen 4K one. Something about the 4K having better GPU than the non-4K? Got it for £100 on a bit of a whim rather than spending £400+ on a new GPU to go in my old PC as an upgrade over the crappy laptop I was using before. Now I'm glad I did. Yes the F@$*%£@* remote is the utter SPAWN OF SATAN when trying to do anything with it. But generally don't need to use it while riding (use companion app, or just press the 'Play' button on remote to activate a powerup), so the frustrations are only post-ride so can take my time and not get frustrated. GPU prices are back down now, but for spending £200+ on an old GPU to go into my 'old' gaming PC (2700K with 16GB ram) I know it would run Zwift, but the hassle of all the other stuff on that PC I'd need to clear off, the hassle of reinstalling it and getting everything working. Just not worth it.
I'd happily replace my AppleTV when the time comes, easily able to justify £100-200-300 on a 'Zwift device' which is cheap enough to sit in the garage only running Zwift (plugged into an old 32" TV) yet experiences no slowdowns, no performance problems, 'just works'. That is worth paying for in my eyes. I'm no Apple fanboy and it is the only Apple device I own. I work with a Directors Macbook and the issues she has really wouldn't use one myself. For context: my daily life is supporting ~57 users on 90+ Windows devices!
