Bad back from previously installing a 4090.Cannot instal it today due to bad back.
Dude pls do not make me laugh , it hurts. I took delivery from DPD Dave and spent next 30 mins on floor in agony so blame the 7900xtx. I am in serious trouble here and cant move out of chair now I am in it.
. My system is clean and tuned for optimal performance with minimal background apps running, aside from MSI AB/HWINFO64 and Corsair iCUE (bit of a perf hog iCue but my AIO needs it).Awesome result from the 7900XTX , punching well above it weight in this game .... no complaints from me the game clearly likes this new architecture@Jay-G25 As requested, MW2 results below Extreme and Competitive Settings using the MW2 build in benchmark at 4K. Extreme uses the standard Extreme quality preset, no other options changed. HUB used the Ultra preset which is one below Extreme for reference. Competitive Settings are using the lowest settings. These are settings below the low preset in game. If you would like to download and test true lowest settings using this preset, download the config file here and place it in your My Docs > COD > Players folder. Download here.
Testing prerequisites
I am running the latest build of Windows 11, with both the AMD and Nvidia drivers installed on my setup. They work perfectly in harmony too,. My system is clean and tuned for optimal performance with minimal background apps running, aside from MSI AB/HWINFO64 and Corsair iCUE (bit of a perf hog iCue but my AIO needs it).
The 4090 is running 527.56, ReBar is at auto setting. The 4090 was run at stock settings and has been repasted using liquid metal. It therefore runs cooler by 5c+ vs normal 4090 GameRocks, the core also moves up a bin due to the lower temperatures. I am using a special performance BIOS that unlocks the power limit up to 660W (stock is 550W) and allows more performance from the 4090 vs the stock BIOS shipped with the GPU. In light of this I will set the power limit to 80% of 550W = 450W to best mimic a true stock 4090. The 4090 was run with 100% fan speed for these tests.
For the 7900 XTX, I installed the 22.12.1 driver. SAM is at auto setting. The 7900 XTX is using the stock thermal paste. The 7900 XTX is limited to a maximum power limit of 335W, it is not possible to raise it further. So the only way to extract more performance is to increase the power limit to +15% which allows up to 335W, and to then lower voltage and finally increase memory frequency. This will net you best overall increase in performance in pure % terms. The 7900 XTX was run with 100% fan speed for these tests.
4090 GameRock Stock (450W BIOS) 1.050v
MW2 Competitive Settings
7900 XTX MBA Stock 335W BIOS
4090 GameRock Overclocked (660W BIOS) 1.100v
7900 XTX MBA Overclock 335W BIOS +15 Power Limit +2778Mhz Memory -150mv Voltage
MW2 Extreme Settings
7900 XTX MBA Stock 335W BIOS Stock
@vapor matt That's about as favourable as you will get for a 4090 in Modern Warfare 2, as my 4090 is tuned to run faster than any 4090 you'll see in a tech review.
Christ we are all getting rather old for all this aren’t we…
Yes as usual no parliamentary procedure when it comes to posting the stock max frequency, I expected no less from folk tbh.@LtMatt whats the max clock looking like will it do over 3ghz ? The other owners need to show their actual in the AMD driver panel.
Yes as usual no parliamentary procedure when it comes to posting the stock max frequency, I expected no less from folk tbh.![]()
There's the front end clock and the shader clock. Typically most folks so far are only showing the Front End Clock in overlays. From my testing so far (need to do more to draw any conclusions) the front end is 2.9-3Ghz and the Shader clock is 3-3.2Ghz. This is what I've seen in Far Cry 6 with my optimal undervolt and overclock profile. 3Ghz is probably a bit too much for the MBA cards due to the 335 Power Limit. AIBs should have no such issue.
Yes, two different clock readings now, check out my new overlay which I'll be using on future AMD videos to YT.LOL
So this is the new indication two different clock outputs ? and I thought hotspot temp was confusing.
Thought so with it being MBA. MPT editing not a possibility then?
Try disabling CSM mode in the BIOS.Got my Saphire XTX today. Haven't been able to get it into Windows.
Went into the bios once so it's not dead.
Asus X570 Tuf Gaming Plus is putting the VGA diagnostic LED on![]()
At 4K it won't be too bad, but below that you'll be CPU limited.Would this GPU be ok with a Ryzen 7 3700X + MSI X570-A Pro ? Or is there no point as it'll be bottlenecked?
It's already off! PSU is 850W but fairly old. Decent EVGA one mind. Maybe i'm on the limit?Try disabling CSM mode in the BIOS.
Update BIOS to the latest and try again. Doubt its anything to do with a PSU.It's already off! PSU is 850W but fairly old. Decent EVGA one mind. Maybe i'm on the limit?
