As far as RT is concerned I share this opinion.
 That was my biggest complaint with the original game visuals, everything looked so cardboard like, now things look grounded and actually apart of the game world.Less than half the performance while looking somewhat worse.
Ray tracing the meme that keeps on giving
Forget about getting games to work that were released after 2003/2004 - they pretty much all use programmable shaders
Unless they have some special compatibility graphic pipelines for older GPUs like Source which until a couple of years ago even supported DirectX 7 via the -dxlevel 70 command
Valve will have supplied Nvidia with an older Portal build to do just that, when you check in the settings menu in Portal RTX you will see that the game is running DX9 but the graphics feature level is limited to DX7
Allowing them to convert straight from DX9 to Vulkan and avoiding any sort of programmable shaders.
I have ripped HL2 from the original disk and it supports the -dxlevel 70 command, sadly it errors out with
"The shared memory map view could not be created (error code 8)!"
Should be easy to get Half-Life 2 running properly in the Portal RTX build tho since Portal was only ever a regular HL2 client running Portal as a mod with the "-game portal" parameter, or in the case of Portal RTX the "-game portal_rtx" parameter
If you launch the hl2.exe in the PortalRTX folder without a -game parameter it's basically just Half-Life 2, but missing assets will crash it among other things.
Swat 4 works well, so a lot of UE2 titles could work. UE1 as well, especially since there is a DX9 renderer plugin for UE1 but those games usually didnt have programmable shaders. Deus Ex should work fine, at least with a proper RTX remix release.
Been testing a number of games, just got Rainbow Six 3: Raven Shield to work after removing the intro videos. Almost exactly like SWAT 4, including the same problems with sky boxes, etc.
Other games which I've got to work: Sniper Elite 1 (menu only), Hitman 2: Silent Assassin (Agent 47 is invisible besides a tie, really hit or miss), Ford Racing 3 (crashes almost instantly but gets in game). Also have seen folks saying Restaurant Empire 2 and Hitman: Blood Money work but I haven't tested those.
There's also a few odd games such as Garfield Saving Arlene and Petz Catz 2 which seem to completely ignore RTX Remix but still show textures normally in the RTX panel. Curious as to how that happens.
Old Tomb Raider games too.Just want Deus Ex RTX. That would make my day. Half Life 2 would be nice too.
Would be nice. Not sure I would play those again though. TR games were almost always a single play through type game for me. Though the last three I could play a couple of times.
Deus Ex I could play over and over every 3 years, like the pre Resident Evil 4 games![]()
 Only a matter of time until they come with proper remix implementation, seriously more excited for these than all the new upcoming games now
 Probably will need a 4090 more for them (if portal is anything to go by) than those new upcoming games tbh, atomic heart what?
All being tweaked/messed about withOnly a matter of time until they come with proper remix implementation, seriously more excited for these than all the new upcoming games now
Zoom in through witcher senses vs normal view:Yes, sadly, but hopefully it will be an easy fix once we can dive into the ini, same as before.
Performance seems a bit mixed for the pre-release build, so maybe it's best to wait for the first big patch.
RT On/Off in different zones (vid below):
What do you mean by no one can run it?Another "L" for RT since no one can run it.
Oh sorry, the 0.000001% who own a 4000 series maybe.What do you mean by no one can run it?
AMD usersWhat do you mean by no one can run it?
Well, I'm running it on rtx2080 at 1080p, so no, plenty of people can run it. Problem is... people want high res, high quality, high frame rate... can't really have it all with last year's hardware.Oh sorry, the 0.000001% who own a 4000 series maybe.
It runs actually but not at a frame rate most here would be fine with at all.AMD users![]()
