really annoying, just can't get it to take. don't know what I'm doing wrongWorked fine on my 4080 FE, didn't take long to install.
anyone else needed to do a firmware update to the 4090 because of the bug where you just have a black screen during boot. No show for bios.
I try using the nvidia firmware tool but it just doesn't seem to do anything. everything goes black while its "updating" but I've left it for like an hour and nothing happens. I can escape out of it fine but I just want it updated
lol what, who can be expected to just have a second GPU laying about ahahaI had to squeeze in a second GPU to successfully flash it
100% managed to plug in the PCIe side without catastrophic failure.99.999% of people mamaged to use both types with no issue & didnt need neanderthal force.
Indeed, flaws in the design of the cable make it easier to screw it up.steve also said its hard to tell when inb properly as his didnt make a sound and you had to apply a **** load of force to be sure, my recent one went straight in same as the old style connectors
People are taking it too far, I hope they saw the Gamers Nexus video. With the wiggle test and plugging the adaptor into the card before putting it in the motherboard it's very difficult to get it wrong.It’s funny because despite that there’s still hysterical people on a Asus Facebook forum I’m a part of who won’t touch their cards until they get an alternative to the Nvidia adaptor and think that if they take the risk their computer will burn down and take their house and family with it. I’m not even exaggerating and that was something I read and I had to reply that perhaps he needed therapy rather than a replacement adaptor lol.
They are big in Asia, I believe they are reputable but have no personal experience with them.Anyone know if Colourful is a reputable brand? It's the cheapest brand avaliable in NZ but cant find much online for it..
Can either grab this one tomorrow or I wait a week for boxing day sales and hope the Gigabyte comes down around this price.
COLORFUL iGame GeForce RTX 4080 16GB Advanced OC-V Graphics Card
COLORFUL iGame GeForce RTX 4080 16GB Advanced OC Video Card, 16GB GDDR6X, Core Clock Base:2205Mhz; Boost:2505Mhz, Power Suggest 850W and aboveextremepc.co.nz
No, mine does not click, so I prob have the less good one. I just pushed it in with a normal amount of force and checked there was no gap. Have had zero issues.
99.999% of people mamaged to use both types with no issue & didnt need neanderthal force. If there was a serious issue Nvidia would have initaited a recall/replacement.
I'll say it again, if you can't insert a cable & check it's inserted, maybe a £1700 GPU is not for you.
Yeah thats exactly whats happening with me.It shouldn’t technically need it from their description, but when I tried I just got a permanent black screen.
Taking an old 10 series card out of my CNC PC and squeezing that just underneath the 4090 was the only way I could get the update program to run properly. No idea why it works for some and not for others.
I guess it’s a good argument for always having some form of built in GPU to the CPU, at least for display purposes for troubleshooting with discrete GPUs.
Has your FE arrived? Happy with it and is it a good clocker if soThe click is there (squid adaptor) it's just v v slight.
Its fairly idiot proof if I remember rightly. You just type "y" and it does its thing. You've checked the firmware version in GPU-Z and it needs updating? Mine that is updated is 95.02.20.00.01
Yeah seems decent enough, boosts around 2950 in game but I've undervolted it to 2800/0.975v for the time being and maxes out around 350w which suits meHas your FE arrived? Happy with it and is it a good clocker if so![]()
