- 21 Jul 2005
- Officially least sunny location -Ronskistats
I've heard of having minimum ram for cpu oc but hiding gpu memory through bios also?![]()
What's the maximum memory temperature you see under load?Loving my XTX 7900 XTX MERC 210. 52 degrees on load.
I get similar amounts of coil whine on the 7900 XTX and the 4090. I've tested 5x 4090s and they all had similar levels of coil whine. 150-200 FPS +, they all make coil whine noise. This can be Timespy, Firestrike, or Warzone or any other game/bench that has FPS in hundreds+. That user makes out the coil whine is only local to a 7900 XTX which is a ridiculous comment to make to be honest.You don't get coil whine in warzone Matt?
I could add a video recording of my 4090 squealing if @Grim5 is in doubt.I will add you to the trusted reputable source sites Matthew!![]()
Any GPU that is switching 300 watts + at 120 times / second + is going to coil whine, i just don't think it's possible to make it silent at that point.I get similar amounts of coil whine on the 7900 XTX and the 4090. I've tested 5x 4090s and they all had similar levels of coil whine. 150-200 FPS +, they all make coil whine noise. This can be Timespy, Firestrike, or Warzone or any other game/bench that has FPS in hundreds+. That user makes out the coil whine is only local to a 7900 XTX which is a ridiculous comment to make to be honest.
All high end GPUs have coil whine. All of them. I guarantee anyone who says my GPU has no coil whine, give it to me and I'll have it squealing in no time at all, and I'm not talking about a menu screen at 1000 FPS.Any GPU that is switching 300 watts + at 120 times / second + is going to coil whine, i just don't think it's possible to make it silent at that point.
It would be interesting if someone on YouTube would turn the power target down on a 4080/4090/7900XTX until the coil whine disappears and then let's see where we're out both in terms of wattage and power. I'd do it myself if i had all three of those. My 3090 it was about 280 watts at the sweet spot.All high end GPUs have coil whine. All of them. I guarantee anyone who says my GPU has no coil whine, give it to me and I'll have it squealing in no time at all, and I'm not talking about a menu screen at 1000 FPS.
The differential factor is that some GPUs clearly have worse coil whine than others, but they all have it, just to varying degrees.
Reducing the GPU voltage, be it via a voltage slider or by lowering the power limit definitely reduces coil whine. Adding more voltage just makes it louder too.The
Not a bad idea that mate.It used to be the way that buying a higher end AIB GPU used to help avoid coil whine.
As the FPS counts have sky-rocketed, that's gone out of the window.
There is no magic, Nvidia only AIB brand that makes golden cards with zero coil whine.
What would be nice @LtMatt is doing a audio/videotest with an FPS limiter on and test at 30>60>90>120>144>etc. fps. to see when the coil whine kicks in.
I don't see the fuss with coil whine.
I only ever experience it with gaming and when I do, I normally have a headset on and I'm fully immersed in the game. Even if I didn't have a headset on, I'd be gaming with speakers and volume turned up.
You lot moaning are either gaming in silence, run 3D Mark all the time or have your PC's sat right next to you on your desk![]()
Not even close. Can't even reach Nvidia unless going back to flarkin' Turing!Other than the 4090 I think AMD win at every price point now, even RT isn't much of a difference anymore due to the higher pricing of Nvidia cards going up against higher tier AMD cards.
paying £1k+ and still having the lottery of coil whine per card let that sink in
