There's always the Nitro+![]()
Yep go the whole hog, XTX Nitro - Best AMD card out there right now, BOOOOM!
Such a shame, it’s such a nice card dimensions wise. Really powerful for such a small card and it feels really nice, all metal. I know some of the AIB cards will offer benefits in terms of noise etc, but this is such a nice form factor…
Yep go the whole hog, XTX Nitro - Best AMD card out there right now, BOOOOM!![]()
Looks like typical wccftech reporting on a random number generator xD
If I turn my case to a similar orientation (which is not sensible as I am using a O11 Dynamic Evo) my hotspot goes to 110c also. However, any other orientation and my hotspot stays below 90c. So I don't think an RMA will fix it in this instance. I guess something about having the GPU that way causes the high temp.I would RMA that if I were you.
Heat pipes usually only work in limited orientations and vertical for this card isn’t one of those clearly.If I turn my case to a similar orientation (which is not sensible as I am using a O11 Dynamic Evo) my hotspot goes to 110c also. However, any other orientation and my hotspot stays below 90c. So I don't think an RMA will fix it in this instance. I guess something about having the GPU that way causes the high temp.
I have my 7900xtx mounted vertically on A 011D-XL.This is most displeasing. With the card mounted vertically (as pictured in post #415), here's what it does after playing Quake 2 RTX for a while:
It's throttling at 110°C, and sounding like a berserk vacuum cleaner.
If I tip my case over so the card is horizontal (fans facing up), then it does this:
Faster, cooler, quieter, as it should be.
This makes the card effectively unusable, which is disappointing as the reference cooler looks well designed, with large fans, unobstructed airflow and plenty of surface area, but the vapour chamber is incapable of handling mavity.
Mine is fine on the normal orientation or using a riser for a vertical mount, but yeah not like that. I've never seen them in that position before tbf.Heat pipes usually only work in limited orientations and vertical for this card isn’t one of those clearly.
I spotted this just now on redditMine is fine on the normal orientation or using a riser for a vertical mount, but yeah not like that. I've never seen them in that position before tbf.
Confirmed then, good find. That backs up my testing.I spotted this just now on reddit
7900 xtx ref.
Orientations tested [avg GPU temp / hotspot temp]:
- I/O down (towards desk) - [54.8 / 77.9]
- PCIe up (Radeon text upside down) - [56 / 85.8]
- I/O up (ports facing ceiling) - [64.1 / 109.7]
- PCIe down (Radeon text correct) - [57.3 / 85]
- Traditional (fans facing floor) - [55.5 / 88.2]
- Inverted (fans facing ceiling) - [55.6 / 87.4]
Which GPU test 2? TimeSpy Extreme GPU test 2 is pretty intensive.What's the best 3D Mark test to test the 7900xtx for stability as GPU test 2 is to light of a load according to Techspot?
I'll have to see if I can send it back and pay the difference to get one of the custom cards. I would have preferred to keep this one though, as it's smaller and uses less power.I would RMA that if I were you.
The wicks that modern heatpipes have in them should allow them to work in any orientation. I'm not going to dig out links now, but I've seen tests showing minimal performance difference even upside down. Vapour chambers aren't pipe-shaped though, so maybe they don't wick as effectively.Heat pipes usually only work in limited orientations and vertical for this card isn’t one of those clearly.
Depends on the wicks. It doesn’t make them work in every orientation.I'll have to see if I can send it back and pay the difference to get one of the custom cards. I would have preferred to keep this one though, as it's smaller and uses less power.
