Late reply, sorry I missed this.I'm about the same with my Corsair 150i.
29 idle, but using chrome and general use I'm at 50-60, bf2042 was I think 70.
Prime, on default hits 90 after a short time.
I think this is fairly normal right?
Way better than my 3900x for sure.
Yes, thats about right.
I have tried Kombo strike. Mode 3 is the best and does about the same as PBOTune2 setting -25 on all cores. Multicore boost is higher but I found it only makes performance worse in games - stuttering / jerkiness / hitching whatever you want to call it.You guys who've played with limbo strike and pbo tuner. Has it made a difference to the boosts you're getting? Especially in games? I mean that's why we have these chips right?
Use kombo strike / PBO / other undervolt method to get slightly lower temps and running benchmarks but for gaming it's best left to do its thing. Gaming max temp i've seen mine his is 73c in Warzone 2. So still way under the max rated temp.
I'm using air cooling
I don't know why anyone is even bothered about running Cinebench, Prime and other tools with the 5800X3D and getting high all core boost and/or higher benchmark scores.
It's main use is gaming, if you want benchmarking chip, you should have probably bought a 5950X or 7950X instead. To play games smoothly, the 5800X3D at stock will work better than both those chips
For test purposes and nobbing around though, sure tweak the chip all you want. I enjoyed at least trying, only to find out it's better left alone
