Underboss
- 20 Oct 2002
- Oxfordshire / Bucks
I was curious, black would be good I think
Quick pic from the other day when I picked it up, not had much chance to play with it yet as I'm back in work till the weekend. Not really planning on doing anything with it other than enjoying it for a while. Will probably swap the mirror caps to black ones as I think it'll suit better, but that's about it.
I would say the Mk7.5 Is rather well equipped as standard, VW do Reverse Camera's well as they are covered which I took for granted until having our Yaris Cross - Constantly filthy, fogged up and rained on meaning it ends up being useless at times.
When I had my 7.5 GTD I changed the mirror caps, the clips are extremely flimsy and being heavy handed I broke one! So be careful when you attempt it.
I'm in the camp where I would agree Black Mirror Caps would look much nicer than the standard silver ones. After the mirror caps are you getting black badges all round to match?![]()
Yeah, as standard it had everything I wanted pretty much. I could live without a reverse camera, but seems easy enough to add and not too expensive. And yeah, the hidden behind the badge cam should keep it clean which is a bonus.
I'll be leaving the VW badges as is, will probably/maybe remove the rear R badge and black out the front one. Did think about removing the front R badge, but leaves a visible hole.
I actually used "Stickers" for my GTD Lettering - Sounds naff! But they leave a slightly chrome around the outline like VW OEM GTI etc.
They didn't lift either, many snowfoams, citrus washes and jet washes no issues.
I didn't want to have to remove badges, re-apply etc just wanted something easy to revert back!
Gave it a quick wash to get rid of the salt and grime, will be dirty again tomorrow!
What's the story with Stingers? Are they still making them new? Always turn my head when I see them on the motorway; very rarely mind you!
You can switch off the sound thing in custom mode.One thing I'm not so sure on yet is the engine noise. I'm not sure how much of it is actually the engine or the soundaktor. I'm going to pick up OBD11 soon so will try and lower the soundaktor volume and see what I think.
Crown image dump.
Must be an unusual trim level. Never heard of that one!
Glad to see they’re still going strong!
