Caporegime
- 9 Nov 2009
- Planet Earth
The RTX4070TI isn't a 70 series card but a rebadged 60/60TI series card. The GPU is under 300MM2 too like a GA106. People keep forgetting Nvidia released an AD103,so the AD104 actually is now the same position as the GA106 in the lineup and the AD103 is basically where the GA104 was positioned.
But more importantly look at the amount of shaders and memory bandwidth relative to the top end dGPU in the range,ie,the RTX4090.
But even ignoring die size,just look at the shader count:
www.techpowerup.com
www.techpowerup.com
The RTX4070TI has 47% of the shader count of the RTX4090,half the VRAM capacity and 50% of the memory bandwith.
Now look at the RTX3090TI vs the RTX3070TI:
www.techpowerup.com
www.techpowerup.com
The RTX3070TI has 57% of the shader count of the RTX3090TI and 60.3% of the memory bandwidth of the RTX3090TI.
Now look at how it is compared to the RTX3060TI:
www.techpowerup.com
It has 45.2% of the shader count of the RTX3090TI and 44% of the memory bandwidth.
The RTX4070TI relative to the RTX4090,is basically what the RTX3060TI was relative to the RTX3090TI for the previous generation,with a die size of the RTX3060/GA106 series.
NVIDIA GeForce RTX 4090 Specs
NVIDIA AD102, 2520 MHz, 16384 Cores, 512 TMUs, 176 ROPs, 24576 MB GDDR6X, 1313 MHz, 384 bit
NVIDIA GeForce RTX 4070 Ti Specs
NVIDIA AD104, 2610 MHz, 7680 Cores, 240 TMUs, 80 ROPs, 12288 MB GDDR6X, 1313 MHz, 192 bit
NVIDIA GeForce RTX 3090 Ti Specs
NVIDIA GA102, 1860 MHz, 10752 Cores, 336 TMUs, 112 ROPs, 24576 MB GDDR6X, 1313 MHz, 384 bit
NVIDIA GeForce RTX 3070 Ti Specs
NVIDIA GA104, 1770 MHz, 6144 Cores, 192 TMUs, 96 ROPs, 8192 MB GDDR6X, 1188 MHz, 256 bit
NVIDIA GeForce RTX 3060 Ti Specs
NVIDIA GA104, 1665 MHz, 4864 Cores, 152 TMUs, 80 ROPs, 8192 MB GDDR6, 1750 MHz, 256 bit
