Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Even better then if within driving distance as you can see it before you buy too.
I did yeah but swapped back to Sony as I wanted to use the 24GM again and the Tamron 35-150 but the size of the 35-150 just made it a chore to carry around.
We’ll see, I’m not set on moving back but I do miss using a Canon body.
If Sony would put their internals in something similar to a Canon body then I’d stick with them but that’ll never happen.
I want to move back to Canon too for a couple of reasons
1 - Colours. I think Canon colours are nicer, and the way the files to process is also easier, the white balance out of the can is more suited to my taste. But i notice the A7R5 has improved
2 - I haven't held a new Canon body though so can't comment how they feel, but my 5D4 was nice, I do miss that. Sony bodies are too short, hence i have to put these bases on to make it taller. I also dislike some of the buttons positions and I dislike how the wheel works. I like the wheel lock on the 5D4 to lock out the presses. The Sony doesn't have that an I constantly hit it by accident.
What put me off however....Canon lenses, the fact that the mount is closed it means there are no 3rd party alternatives. The price of a 85L is like £3k, a 85GM is half that. It also doesn't help that i sold all my EF lenses so it's not like I can adapt it as a stop gap lol. The flashes are also insanely expensive. I thought the 600EXRT was expensive? I think the new ones are like £1k now.
Basically, to get a full Canon set up would be in the region of like £20-25k. And they still don't make a RF mount 35L. Lastly, their lenses are now massive, they have decided to pit IBIS inside some of the lenses too, which is great, except it makes them massive. I quite like the small 35GM now.
I am going to stick with Sony mostly down to cost, the colour science thing, it will trickly down and I will live with everything else.
Quick sum with UK pricing. And missing 24 and 35L so using current versions and missing Canon flashes, but it seems 600EX-RT works so probably go for those. I put in an R6 just because, but 20mega pixels seems low, I would much prefer if they went up to 24.
It's no small change! Those L Primes on RF are Luxury indeed!
