Many thanks.I still would want a better cooler than a 240mm preferably 360mm especially if your going to load them 16 cores .
Your always going to sacrifice a few degrees increase on the gpu if you put the rad at the front but it's about airflow as well moving heat out of the case. Reversally if you have a high powered gpu dumping heat into the case then cpu temps can increase slightly.Many thanks.
I think as has been mentioned unless I start moving fans around etc etc that would mean a different case.
What would you advise, changing the configuration of the existing case or changing cases?
That's fine 3060Thanks and re the GPU, none to start with as my main use for this (PixInsight astro image processing) doesn't really utilise a GPU right now. That's not entirely accurate but it's additional processes like Starnet2, NXT and so on that use it so no big deal (to me) at the minute.
There are plans to change this so if it were to happen "tomorrow" I'd probably go for a 3060.
Thanks and I must admit I'm torn here now as I had sort of decided to go with the Arctic 240mm if putting it in the top. It's not a huge jump to the 360 so would that still be a better bet over the Aerocool if I'm going for a front mounted unit?That's fine 3060
Here is a list of AM5 coolers on overclockerss if you want to check them out, the aerocool mirage 360mm looks a good value option if you decide to go bigger.
AM5 Coolers
Keep your AMD Ryzen 7000 Series CPU at optimum temperatures with an AM5 cooler from Overclockers UK, ideal for quickly and efficiently dissipating heat.www.overclockers.co.uk
Yeah tell me about it....Hehe you have fallen down the hole of endless choices. Lots of good options and in the end you will have to make your own mind up.
I'd not seen the III listed as I was looking in a different section but thanks for adding to the priceif you like the lancool case the lancool III allows a 360mm aio in roof...bit more money though, but I like that the sides swing out though..easy for cleaning/tinkering
Nothing else.Hi again, just one last thing (I think) but is there anything else I need to get this build working? I'm speaking about cables, adapters etc rather than monitor, keyboard and the like?
Your welcome.Great thank you
