When you say everything at max do you mean you physically went through every image quality option and maxed them out? Or do you mean you choose the extreme quality preset. I ask as the latter is not truly maximum settings.I've got the xtx, just ran the mw2 benchmark, 1440p everything at max, the end result was around 140fps, seems rather low. Junction temp hits around 86, pwr is around 380w. Tried a fresh driver install but didn't help.
Are you using the MBA card? If so, try the following:
- Set power limit to +15%.
- Set fan speed to 100% and disable zero RPM (for the purposes of this test).
- Set memory frequency to 2750Mhz with fast timings enabled.
- Set core clock to 3000Mhz, leave min frequency at 500Mhz.
- Adjust core voltage to 1100mv.
- Click Apply.
- Navigate to the My Documents > Call of Duty > Players > options.3.cod22 file and open with Notepad. Scroll to the bottom and change RendererWorkerCount:0.0 = "7".
- Save and launch the game.
- Go through each menu image quality option and max it out. Also enable Fidelity FX Cas too and set that to 100%.
- Keep the Radeon Ingame Overlay off for now, it costs a couple of FPS to have it running
- Relaunch the game and run the benchmark.
- If it crashes put GPU back to stock settings, but max out the power limit, fan speed and rerun the bench and share your results.
Sapphire Nitro XTX Stock
Sapphire Nitro XTX Overclocked
