Started playing this recently, taking it slow and learning as I go. Bloody fun though.
Is there a way to send hunting caravans to other tiles?
Could use some more meat before winter and I don't want to genecide everything in my own tile.
I'm playing vanhilla with no mods.
On vanilla only if you got ambushed en route and it generated a battle map that you could hunt on before moving on.
There is a mod that allows caravans to set up a camp site on the current tile that you could safely add mid game.
So there's no way I can bring back corpses/meat from say a mission, without using the mentioned method?
re-save load.. but this was also my first play through.
When it comes to walls around my base for protection/choke points. Should I be aiming for stone, or will wood do the job?
Also, when it comes to work prorities. If I set it to manual and leave everything at a 3, will they still just work from left to right?
