hmm perhaps too late, apolsimgbb is what I normally use for image hosting. Link the bbcode or html code and should show up in forums. Pls do not link a pic until you have fixed the unicorn vomit , we have been nice and should not be traumatised.
Nice.
Thanks and agreed. didn't mention it but cable tidying hasn't been done yet as I'm still only testing really and also need to fit the bottom fans. However, duly notedNice.
Just a bit of cable management to tidy, mite need a couple of extensions and once all the Rgb is sinked will look even better.
Good job.
The leads have been behind already, you cannot see from the image but behind/below the AIO are the grommets and it's fairly easy to push the cables through so no worries there.You should have threaded the Al120 fan leads behind the mobo before you put the AIO in. Will not be easy to move it now without removing the aio.
Your build does look lovely but empty without a gpu. I adore how the current Asus mobos look with the brushed metal covers over the M.2 drives. When you do get a gpu it will be hard to get one as nice as your other components , the 3060 level of cards are built to a budget and the coolers generally just have plastic covers over the fans. Zotac do a white version but once you go that route you are paying the white tax and costs more for the same corresponding part. Also coming to eol for a lot of the Ampere cards so if you want a white one dont wait too long.
That looks so much better , well done.
Thank you, I'm very pleased with the performance, it's incredible compare with my old machine....
I'm not really a gamer but happy to give it a go, any recommendations please?Any plans to test the intergrated graphics with a game?
720p low detail should be achievable.
Here are the best free games on pc if you fancy a try.I'm not really a gamer but happy to give it a go, any recommendations please?
Ok thanks had a look and managed to steer myself through various logins etc and I think I'm installing League of Legends.... No idea whether that is good, bad or indifferent but it was on that list so I'll soon find out....Here are the best free games on pc if you fancy a try.
The Best Free PC Games for 2025
Put down the plastic and pick up a controller to play these top, no-cost PC games for desktop, laptop, or handheld PC.uk.pcmag.com
The PBO setting said "ECO Mode" so I assumed it was the right thing to do
