I just use presets, life is too short.
Motion blur is an auto-off in any game.
Ok, I'll bite. To what resolution would you go? Why?
Although Motion blur helps to make low framerates a little bit more tolerable to the eye.Motion blur if i needed frames.
Couldb you explain that slightly? Why if in the near future?
I know this isn't directed at me but I feel like answering. After upgrading to a 4K (2160p) display, I found that setting the game to 2560x1440 (not resolution scaling, literally setting the output resolution lower) and letting the TV upscale that to 3840x2160 looked 98% as good, and sometimes looks and runs better than DLSS or ingame resolution scaling. But I have LG OLED and the inbuilt upscaler is quite good, upscalers on PC monitors are often of lesser quality compared to TVs and sometimes completely absent, i.e. the monitor just does nearest-neighbour upscaling which looks like crap.
Problem is that motion blur is designed to make animated image look smoother with low FPS. Hence, if FPS isn't an issue it would be off most of the time but if FPS is below 60 it can help a lot with it feeling jerky.I turn this off even if I don’t need the extra FPS.
LG supposedly uses AI in their upscaling (depending on the model), so it might not be that far off DLSS.Agreed about the settings tweaking
I'll have to try this upscaling out on my LG now. I know for even DVDs it does a good job that i am happy with.
