Didn't you start ~110kg though so still in a great place (at least that's my memory from the running thread)
Yeah that probably makes sense to do that, although my exercise is mostly around 500kcl max, so even accounting for eating those calories my total consumed would be 2k max anyway.
I guess it depends what exercise you're doing? Most of mine is plunged into my weekends where I might cycle for maybe 5 hours. I don't think I could survive on base cals after that.Eating back calories burned through exercise is where so many peolpe go wrong with consistent weight loss goals.
I think this is closer to what I do. I accept if I've burnt 2k cals in the morning, I am going to need to eat a bit more, but not 2k's worth!Interestingly Noom only gives you back half of the calories burned through exercise.
That's not what I suggested, you can apply an activity modifier to your BMR calculated calories and then spread that out over the week. Say your BMR is 1500, your activity level takes that up to 2k, you can sit on 1750 for 5 days of the week, carb up before your ride day on 2500 and then have 2500 the day of/after your ride etc. Total calories over the week is fixed, you've distributed them to account for your activity, and you haven't fluctuated based on pretty loose calorie burn tracking devices.I guess it depends what exercise you're doing? Most of mine is plunged into my weekends where I might cycle for maybe 5 hours. I don't think I could survive on base cals after that.
Yeah, sure... but tbf that's not what you suggested above, thats all. You said pick 2k (or a number) and stick to that regardless of exercise. I'm set at 2.4k and still feel the need to go over on big days. I'm suggesting when you burn 2k to 3k in one morning, you need to up it a reasonable amount. I've done this and still successfully lost weight. For example on Saturday, I ate closing in on 4k cals, but I burnt, according to Strava... around 2.5k, which I'm comfortable with. If I was really pushing weight loss, I would have stayed closer to 3k cals consumed, but I would have definitely needed to up the amount a reasonable bit or I might have been feeling a little unwell tbh.That's not what I suggested, you can apply an activity modifier to your BMR calculated calories and then spread that out over the week. Say your BMR is 1500, your activity level takes that up to 2k, you can sit on 1750 for 5 days of the week, carb up before your ride day on 2500 and then have 2500 the day of/after your ride etc. Total calories over the week is fixed, you've distributed them to account for your activity, and you haven't fluctuated based on pretty loose calorie burn tracking devices.
I should have been a little clearer sure but i felt the base level of knowledge on how to set calorie requirements was sufficent to know that when i said pick a calorie amount, that a certain level of thought goes in to it.Yeah, sure... but tbf that's not what you suggested above, thats all. You said pick 2k (or a number) and stick to that regardless of exercise. I'm set at 2.4k and still feel the need to go over on big days. I'm suggesting when you burn 2k to 3k in one morning, you need to up it a reasonable amount. I've done this and still successfully lost weight. For example on Saturday, I ate closing in on 4k cals, but I burnt, according to Strava... around 2.5k, which I'm comfortable with. If I was really pushing weight loss, I would have stayed closer to 3k cals consumed, but I would have definitely needed to up the amount a reasonable bit or I might have been feeling a little unwell tbh.
If I'm only burning 500 to 5k cals, I think I can get away with staying at target. When I have a long cycling weekend, I do a little like you say and increase my target a few days before and probably a few days after to recover.
I thought that was specifically what we were discussing was all, so confused me. Someone said 'I use some of what I earn', you said 'you shouldn't do that' and now you're saying we should use common sense and you should sometimes.I should have been a little clearer sure but i felt the base level of knowledge on how to set calorie requirements was sufficent to know that when i said pick a calorie amount, that a certain level of thought goes in to it.
Set a fixed number, spread it out / use it how you want. The important bit is don't have a moving target and expect consistency.I thought that was specifically what we were discussing was all, so confused me. Someone said 'I use some of what I earn', you said 'you shouldn't do that' and now you're saying we should use common sense and you should sometimes.
We're both essentially agreeing to the same point though, you shouldn't for the smaller stuff, but sometimes you have to to enable the bigger stuff, but do it within reason. Just misunderstandings I guess![]()
Oh okay, we don't essentially agree thenThe important bit is don't have a moving target and expect consistency.
so we'll just agree to disagree
No we agree, i think your missing that ive said you should factor in activity as part of your calculation for calories required. Your example of a once a week 5 hour bike ride can be counted as your activity modifier. If your preference is to eat more before and after the ride, thats fine, as long as your weekly total isnt higher then 7x the calorie amount you calculated using your BMR and activity modifier.Oh okay, we don't essentially agree thenso we'll just agree to disagree
and is probably in that 1% with me.Yeah, so I would go a different route (and do) as sometimes I'm lucky enough to get out during the week or alternatively I might be unlucky and can't exercise at the weekend. Last week I cycled on Tuesday too. That's not normal and wouldn't be covered in a standard weeks activity. Or... there are some weekends I might do 120 miles and some I might only do 80, which takes different fuelling. So, I would rather go with a base that covers smaller activities and then add in cals as necessary on days I exercise 'big'.
Consistency is great, but not always possible. (Sometimes in a good way) If I have a week off I'll need to eat a LOT more as I'll cycle almost every day.
For 99% of people your approach is nice and simple and the best way to go. I only brought it up as you were talking to @Martynt74 who sometimes goes running for like 3 days none stopand is probably in that 1% with me.
1500 is low for a BMR for someone your proportions (ie height etc) mine is 1650. I would start at a stable 2k, then work down from there if/when needed.For me, i think setting 1800/day and then not eating calories probably works, that's 7*300 kcal over a week above the 1500/day setting to lose 2lbs a week, but allows for a more even distribution of calories throughout the week.
Guys, what's the website for working out your maintain/lose/gain cals? I used to use a good one, but it got shut down.
I currently use this one:
Harris-Benedict Equation
Free BMR calculator to calculate your Basal Metabolic Rate. Learn how many calories your body burns at rest.www.bmi-calculator.net
Assuming that has used the oxford formula, which doesnt factor in bodyfat, which can move the scale a fair bit. Sedentary as well doesn't mean doing absolutely nothing, there's an assumed level of base activity and from what i tracked to the nth degree is that sedentary seems to imply 5k steps per day!! All the forumla are at least 15+ years old when we were still giving out the 2.5k cals per day for everyone advice!That seems to think that I need 2400 kcal to maintain my weight if I were sedentary or 2800 kcal if lightly active. I’m trying to stick to around 2000 a day, although the pace of my weight loss (or lack of!) probably suggests that I’m not logging a few calories here and there. I just need to be patient, what I like about my current plan is that I can actually eat the things that I enjoy!
