hi
if you are worried about 1 battery specifically.... I have 3x2.4kwh abd each one has 5 LEDs on the front of the battery indicating charge levels. if one of your batt3ries is faulty I would expect that to show on the display
mine only discharge to 20% so I only get 6kw/h out of mine .... the software lets me go as low as 5% however if I do I don't get the 5 year warranty on the battery, it goes down to 2 years so I have to keep as is.
my system is 18 months old and my battery health is already dropping.
. (SOH 96%). not sure how low it can go before I claim on warranty.
my system is in the attic. the insulation is all on the floor in the attic so it gets some wild swings. the inverter is mostly passively cooled via a big heat sink but if it get hot it does have a cooling fan which comes on from time to time.
edit.... below is wrong... that is the inverter temps not battery.
right now internal battery temp is 19 degrees. it's max operating temp is 105 degrees. not sure what minimum is
