You are correct, 1 hour will normally spot bad RAM but a full cycle is the best option. I have not used MemTest86+ for a long time, the last time I used it, it took ~1 hour to do a full cycle.Looking at that screen shot the test is only 54% through and the CPU pass is at 24%, it really needs to be 100% on both to to be considered ok.
No, you have 32GB, last time i ran it, i probably had 8GB, maybe less. Also, the software has changed a lot.So it's taking longer than normal?
Anyone else want to test for an hour ?![]()
If it was me, I would turn EXPO on and try it again just to see what happens. If the CPU cannot handle it, it will probably error in the first few mins.OK thank you mate
Worth me doing it again then until 4 passes are done?
Never used it so? Did you run the RAM with EXPO on?Does prime 95 ever finish ?
been going nearly an hour now
