- 30 Nov 2011
Yes exactly, 40-50fps feels horrible to me, I'm not going to be playing at settings (regardless of FG or not) that feel like 40-50fps (50ms is actually 20fps type response times). I will lower settings to get actual real 120fps, I won't enable RTX if it drops me to 50fps and then I have to try to joke myself in to believing na fps counter that says 120fps when it's actually running with 50ms of input lag because that will feel awful TO ME.But that is what im trying to explain to you. YES, the game will feel laggy in terms of input but not because of the FG but because your actual framerate is 40 fps. So even with fg off, the input lag would still be horrible. FG doesn't create the input lag problem, it just doesnt fix it. Arguably, it even makes it a bit worse, but still thats because your original input lag without fg is horrible
You repeatedly said to me "YOU won't feel it" but I can tell you unequivocally that I will feel 50ms of input lag and it will feel awful, again, TO ME.
If 50ms input lag is the cost of RTX then it is not a cost worth paying, to me.
