Problem is though even reducing textures to low does not fix the performance.........
Surely putting the main setting responsible for VRAM usage down to its lowest setting should solve the problem? That's how this is suppose to work according to folks here isn't it?
On a slightly separate note, based on my own testing between ultra and high preset at both 3440x1440 and 4k, I can hardly see a difference between the presets.
However, what does fix/improve the performance considerably as confirmed by a **** ton of people now (including myself and 2 others on this forum [haven't checked since last night to see if others have noted the same])
					www.reddit.com
But nope, just lack of vram the sole cause of these problems here, nothing else at play.....
The only way this would be 100% genuine vram shortage is if none of the above was possible i.e. instead, reducing textures fixes vram the issue and manually putting in changes yourself doesn't boost the fps/performance more than changing settings) among the following not happening:
- gpus with plenty of vram are also ******** the bed at 1080P e.g. 7900xtx
- in cut scenes, fps plummet but in gameplay, goes back up
- casting a spell causes the fps to shoot straight back up even though nothing else has changed/happened in the frame
- vram usage isn't any different between 1080p and 4k (also, just to add even when I have dlss performance mode enabled, vram usage also didn't drop, another thing which goes against the standard of what you would expect to happen)
- people even at 720P getting drops to 10-20 fps with everything on low
Sooner people start to call out bad optimisation and dodgy **** like the above, the better for the gaming industry otherwise keep enjoying paying through the mouth for the best hardware to overcome obvious game development issues and even then, that still isn't enough.......
				The way you have described the situation means you dont understand the problem.  You are right, I haven't,, cause nobody explains it to me. They just claim it's a problem. Is it a problem that I have to also drop settings on a brand new 1300€ 7900xtx? Or that's okay, but dropping settings on a...
					forums.overclockers.co.uk
Sorry I keep forgetting, computerbase, pcgamershardware, TPU, Jansn aren't trusted source any more, only HUB is.
