Russia may have lost an entire elite brigade near a Donetsk coal-mining town
‘Almost the entire brigade has already been destroyed near Vuhledar,’ Ukrainian official says.
It's horrific but only matters if you put a value on a human life. So long as some land is captured(no matter how small) to the Russian govt how many people die does not matter. the mission advances..Damn...almost a thousand men per day. This is really the modern day stalingrad
Its WW1 all over again then lolIt's horrific but only matters if you put a value on a human life. So long as some land is captured(no matter how small) to the Russian govt how many people die does not matter. the mission advances..
Hopefully true! Hopefully less likely to held to the whims of a slightly unhinged billionaire.Reports are coming out that Kymeta will replace Starlink for satellite communications over Ukraine, which is good news if true.
**** Musk
**** Musk
Sadly thats what Russia mostly does. Try to swarm the enemy by sheer numbers.
Its like if fail you keep trying same tactic and kill more of your men in doing so.
If the zerg doesn't work, then send another zerg to see. If the they are not wiped out easily it means the defences are less effective so you know where to attack nextSadly thats what Russia mostly does. Try to swarm the enemy by sheer numbers.
Explains why the daily death rate for the Russians has gone up suddenly. It’s 824 a day now.
Ukraine really need to stop being on solely the defensive. Eventually Bahmukt will fall if they simply defend. Obviously I'm not army trained in any way, it's just obvious to me, when the attackers are just considering their men as another disposable item.
