The Radeon RX 7900 XT(X) Owners Thread.
15 Feb 2003
NJ/NY, USA
17 Dec 2015
WOuld there be any point in me grabbing a 5800X3D - Currently on an 5800X standard, but obviously have my 7900XTX - I game mainly on my 4k TV downstairs so not sure there would be much point for the cost at that resolution?
I did exactly that. I swapped my 5800X for a 3D. It improved my fps significantly. Much cheaper than a 7000 series upgrade.
17 Dec 2015
I had a Corsair HydroX 3080 rig. That also corroded but that was my fault. There are some nice photos in r/watercooling of my stuff somewhere.
17 Dec 2015
I’ve never played it. My card is great. My issue is that the hit is too great when recording for me. It’s a 50fps drop. I record for review purposes so I can see what mistakes I’m making etc. This is esp useful with BR games.
23 Dec 2022
London
I’ve considered this myself but analyzing my (many) mistakes would take to long .
Caporegime
12 Jul 2007
United Kingdom
With AMD, I find it's best to use HEVC for recording. The quality is good (better than AMD H.264), the file sizes are smaller (than AMD H.264), and the performance hit from recording is 1-2FPS.
It's one area where the XTX does better than the 4090, gameplay recording hit. The 4090 costs around 5-6 FPS vs recording, whereas HEVC on the XTX costs me 1-2 FPS.
These are the settings I used if anyone would like to try them.
XTX - HEVC, 100Mbps, 60 FPS, AUDIO 112Kbps - using AMD Software ReLive.
4090 H.264 100Mbps, 60 FPS. Can't adjust audio quality - using Nvidia Shadowplay.
On AMD you can also use the AV1 codec for recording. It's slightly better quality vs HEVC but also has a similar performance hit to H.264 on the 4090.
17 Dec 2015
I’ll have another look. I’m in 1440p and hevc looked blurred. I’ll up the bitrate and have another go.
