Letter will be in the post…I take it because I re-contracted last month I won’t get the price increase
Just say you can't afford it anymore, there is no argument about anything then I find.The problem I always have, come negotiation time, is that I'm a heavy user and I have no viable alternatives as there's no FTTP here (and I suspect they know this) which weakens my bargaining position and any threats to leave.
I also only take broadband from them so there's no bundle they can 'manipulate'.
I highly doubt it, they cannot keep up on every alt net provider. Just blag them.and I suspect they know this
I think that's a fair priceI blagged it and said an alt net was building in my area very soon. They have done some streets quite close by, but there are no plans in the immediate future to cover mine.
Managed to get Gig1 down to £28 after a few attempts.
I'm quite surprised at how these 5's hold up.Power level is a bit high but within spec, can be brought down by engineer moving you to another tap in the green cab or by fitting an attenuator. Rest looks fine.
| Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
| 1 | 306000000 | 9.5 | 41 | QAM 256 | 22 |
| 2 | 138000000 | 10 | 40 | QAM 256 | 1 |
| 3 | 146000000 | 10 | 40 | QAM 256 | 2 |
| 4 | 154000000 | 9.8 | 40 | QAM 256 | 3 |
| 5 | 162000000 | 9.9 | 40 | QAM 256 | 4 |
| 6 | 170000000 | 9.9 | 40 | QAM 256 | 5 |
| 7 | 178000000 | 9.7 | 40 | QAM 256 | 6 |
| 8 | 186000000 | 9.9 | 40 | QAM 256 | 7 |
| 9 | 194000000 | 9.8 | 40 | QAM 256 | 8 |
| 10 | 202000000 | 9.6 | 40 | QAM 256 | 9 |
| 11 | 210000000 | 9.7 | 40 | QAM 256 | 10 |
| 12 | 218000000 | 9.1 | 40 | QAM 256 | 11 |
| 13 | 226000000 | 8.8 | 40 | QAM 256 | 12 |
| 14 | 234000000 | 8.2 | 40 | QAM 256 | 13 |
| 15 | 242000000 | 7.5 | 40 | QAM 256 | 14 |
| 16 | 250000000 | 7.7 | 40 | QAM 256 | 15 |
| 17 | 258000000 | 7.5 | 40 | QAM 256 | 16 |
| 18 | 266000000 | 7.1 | 40 | QAM 256 | 17 |
| 19 | 274000000 | 8.4 | 40 | QAM 256 | 18 |
| 20 | 282000000 | 9.1 | 40 | QAM 256 | 19 |
| 21 | 290000000 | 9.4 | 41 | QAM 256 | 20 |
| 22 | 298000000 | 9.6 | 41 | QAM 256 | 21 |
| 23 | 314000000 | 9.7 | 41 | QAM 256 | 23 |
| 24 | 322000000 | 9.7 | 41 | QAM 256 | 24 |
| 25 | 330000000 | 9.7 | 41 | QAM 256 | 25 |
| 26 | 338000000 | 10.2 | 41 | QAM 256 | 26 |
| 27 | 346000000 | 10.3 | 41 | QAM 256 | 27 |
| 28 | 354000000 | 10.6 | 41 | QAM 256 | 28 |
| 29 | 362000000 | 10.9 | 41 | QAM 256 | 29 |
| 30 | 370000000 | 10.2 | 41 | QAM 256 | 30 |
| 31 | 378000000 | 9.5 | 41 | QAM 256 | 31 |
| Channel | Locked Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
| 1 | Locked | 41 | 47 | 0 |
| 2 | Locked | 40 | 77 | 0 |
| 3 | Locked | 40 | 76 | 0 |
| 4 | Locked | 40 | 88 | 0 |
| 5 | Locked | 40 | 94 | 0 |
| 6 | Locked | 40 | 85 | 0 |
| 7 | Locked | 40 | 92 | 0 |
| 8 | Locked | 40 | 84 | 0 |
| 9 | Locked | 40 | 90 | 0 |
| 10 | Locked | 40 | 92 | 0 |
| 11 | Locked | 40 | 82 | 0 |
| 12 | Locked | 40 | 83 | 0 |
| 13 | Locked | 40 | 81 | 0 |
| 14 | Locked | 40 | 96 | 0 |
| 15 | Locked | 40 | 84 | 0 |
| 16 | Locked | 40 | 97 | 0 |
| 17 | Locked | 40 | 69 | 0 |
| 18 | Locked | 40 | 74 | 0 |
| 19 | Locked | 40 | 49 | 0 |
| 20 | Locked | 40 | 55 | 0 |
| 21 | Locked | 41 | 41 | 0 |
| 22 | Locked | 41 | 48 | 0 |
| 23 | Locked | 41 | 55 | 0 |
| 24 | Locked | 41 | 65 | 0 |
| 25 | Locked | 41 | 52 | 0 |
| 26 | Locked | 41 | 42 | 0 |
| 27 | Locked | 41 | 43 | 0 |
| 28 | Locked | 41 | 50 | 0 |
| 29 | Locked | 41 | 58 | 0 |
| 30 | Locked | 41 | 43 | 0 |
| 31 | Locked | 41 | 67 | 0 |
| Channel | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
| 0 | 53700000 | 43.8 | 5120 | QAM 64 | 1 |
| 1 | 46200000 | 43.8 | 5120 | QAM 64 | 2 |
| 2 | 39400000 | 43.5 | 5120 | QAM 64 | 3 |
| 3 | 32600000 | 43.3 | 5120 | QAM 64 | 4 |
| Channel | Channel Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
| 0 | ATDMA | 0 | 0 | 0 | 0 |
| 1 | ATDMA | 0 | 0 | 0 | 0 |
| 2 | ATDMA | 0 | 0 | 0 | 0 |
| 3 | ATDMA | 0 | 0 | 5 | 0 |
Spoke to tech support again who are now saying the levels in my downstream are off and I have another engineer booked. Can someone that understands these levels take a look please, what should they actually be in the downstream
Downstream bonded channels
Channel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID 1 330000000 6.8 41 QAM 256 25 2 162000000 6.3 41 QAM 256 4 3 170000000 6.1 41 QAM 256 5 4 178000000 6.1 41 QAM 256 6 5 186000000 6.3 42 QAM 256 7 6 194000000 6.8 42 QAM 256 8 7 202000000 6.9 41 QAM 256 9 8 210000000 7.2 42 QAM 256 10 9 218000000 7.3 42 QAM 256 11 10 226000000 7.1 42 QAM 256 12 11 234000000 7.1 42 QAM 256 13 12 242000000 6.8 42 QAM 256 14 13 250000000 6.9 42 QAM 256 15 14 258000000 6.9 42 QAM 256 16 15 266000000 6.9 42 QAM 256 17 16 274000000 6.9 42 QAM 256 18 17 282000000 7 42 QAM 256 19 18 290000000 7.1 42 QAM 256 20 19 298000000 7 42 QAM 256 21 20 306000000 7 42 QAM 256 22 21 314000000 7 42 QAM 256 23 22 322000000 7 41 QAM 256 24 23 338000000 7.1 42 QAM 256 26 24 346000000 7.3 42 QAM 256 27 25 354000000 7.1 42 QAM 256 28 26 362000000 7.5 42 QAM 256 29 27 370000000 7.4 42 QAM 256 30 28 378000000 7.6 42 QAM 256 31 29 386000000 7.5 42 QAM 256 32 30 394000000 7.5 42 QAM 256 33 31 402000000 7.6 42 QAM 256 34
Channel Locked Status RxMER (dB) Pre RS Errors Post RS Errors 1 Locked 41 0 0 2 Locked 41 0 0 3 Locked 41 0 0 4 Locked 41 0 0 5 Locked 42 0 0 6 Locked 42 0 0 7 Locked 41 0 0 8 Locked 42 0 0 9 Locked 42 0 0 10 Locked 42 0 0 11 Locked 42 0 0 12 Locked 42 0 0 13 Locked 42 0 0 14 Locked 42 0 0 15 Locked 42 0 0 16 Locked 42 0 0 17 Locked 42 0 0 18 Locked 42 0 0 19 Locked 42 0 0 20 Locked 42 0 0 21 Locked 42 0 0 22 Locked 41 0 0 23 Locked 42 0 0 24 Locked 42 0 0 25 Locked 42 0 0 26 Locked 42 0 0 27 Locked 42 0 0 28 Locked 42 1 0 29 Locked 42 0 0 30 Locked 42 0 0 31 Locked 42 0 0
Upstream bonded channels
Channel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID 0 49600000 45.8 5120 QAM 64 1 1 43100000 46.3 5120 QAM 64 2 2 36600000 47 5120 QAM 64 3 3 30100000 47.3 5120 QAM 64 4 4 23600000 47.3 5120 QAM 64 9
Channel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts 0 ATDMA 0 0 0 0 1 ATDMA 0 0 0 0 2 ATDMA 0 0 0 0 3 ATDMA 0 0 0 0 4 ATDMA 0 0 0 0
I'm also a heavy user and my area has no alternatives for high-speed BB, but you still can negotiate. Just say you want to cancel and are not interested to hear about any deals. Let them put you on the cancellation team and you will get better offers. However, if you still want more discount just go ahead to give 30 notice and wait for the retention team to call you.The problem I always have, come negotiation time, is that I'm a heavy user and I have no viable alternatives as there's no FTTP here (and I suspect they know this) which weakens my bargaining position and any threats to leave.
They offered me my 250mb broadband for £23 to try and get me to stay. I had been paying £44 a month.
I knew they'd been gouging for years though, but there was no viable alternative.
Glad I told them where to go
Enjoying my 900mb fttp for £30 a month.
It's city fibre through Vodafone. Got an offer through the post as city fibre had just laid the network in my area.Who is that with, and how did you get it for that price?
Was great timing as my virgin contract had just run out the week before![]()
I think they do periodic deals. If you're prepared to wait, something will come up.Nice one.
I haven't had my price increase notice from Virgin yet, but looking at alternatives, of which Vodafone is one, but not at your price!
Snap.They offered me my 250mb broadband for £23 to try and get me to stay. I had been paying £44 a month.
Mine was £36 for M250 with “mix TV” - Eurosport & few others in HD.the price of your package will go up by £7.00 a month from 1st May 2023.
So £33 to £40 for M250
