ASUS 42" ROG Swift PG42UQ
Did anyone of you give feedback to Asus about the current Firmware issues? personally I have some problems when switching to a HDR game it losing connection sometimes with DP/138 Hz. Then I have to manually use the remote and alt tab to wake it back up.
Кто-нибудь из вас оставлял отзыв Asus о текущих проблемах с прошивкой? лично у меня есть некоторые проблемы при переключении на HDR-игру, иногда теряет связь с DP/138 Гц. Затем мне приходится вручную использовать вкладку «пульт» и «альт», чтобы разбудить его.
I have the black screen sometimes on 138hz via HDMI so run at 120hz.
I got my PG48UQ for half price when there was a glitch, otherwise I wouldn’t have bought over a C2.
This is beyond infuriating - Asus still haven't fixed HDR on this monitor and it's been nearly 3 months, I'm starting to lose hope on any firmware update given their neglectful responses to people on Reddit (there's several threads on /r/OLED_Gaming). It's a damn shame because it is the best monitor for my needs and there's only one of a kind on the market (42" 4k120 16:9 OLED monitor with DP). I know the LG C2 42 is a clear option but I went out of my way to pay the premium to get this in PC monitor form. I already have a QD-OLED A95K TV anyway and owned a S95B briefly until I saw a side to side comparison between the two (off-topic I know).
My previous display for my workflow and mild gaming was a AW3821DW (38" 3840x1600p 144hz UWD 21:9). The natural upgrade would have been the QD-OLED version of that very same panel in 38"/1600p but instead we got a 34" 1440p version (AW3423DW as you know) which I've tried and loved, but I just couldn't go back to a downgrade in screen real estate for my workflow. 38" 1600p was definitely a sweet spot for productivity. Anyway, I finally built a new PC for myself with the most logical choice in terms of display upgrade (i9-131900KS/RTX 4090 Strix OC/2x64 GB DDR5-6400-CL32/Maximus Z790 Extreme/2TB 990 Pro + 4TB WD SN850X/H170i Elite LCD XT AOI/EVGA SuperNova 1600W P2 80+/Cooler Master HAF 700 Evo Full ATX Tower/PG42UQ 42" 4k138hz 16:9 OLED).
It's been a little over two weeks but I am definitely disappointed with the lousy HDR implementation with triple A gaming titles. The display itself looks absolutely fantastic in full OLED as a workstation and gaming in SDR, the matte coating doesn't bother me at all and I have a 65" Sony A95K QD-OLED TV downstairs in my living room with a full soundsystem via eARC for comparison so I get the appeal of glossy OLED but as far as a monitor goes this is still ideal for me. I can have my workflow distributed over 42" 4k OLED in 16:9 real estate (same setup as my AW3821DW but taller windows in pixels since the horizontal pixel count is the same). I can play single player games with full immersion using the entire 42" in glorious 4k OLED, and when I want to play competitive FPS games I can easily use the module to downscale to 27" 1440p or 24" 1080p. I believe the most sought after monitor at this time is a 32" 4k240hz 16:9 OLED monitor but it would not be economically viable for manufacturers since it would probably cost $3k+ a piece due to the way the mother glass is cut. It's cheaper to produce 42, 48, 55, 65 and so on for OLEDs and we probably won't see QD-OLED on a 38" UWD for years as well.
Anyway, I came here to post what has already been posted a page back: a very solid guide on how to bandaid fix/workaround HDR issues with games. This has worked very well for me (from the correct firmware updates to the NVIDIA control panel settings to the windows 11 calibration test). I used the above setting with several new games including Dead Space, it definitely looks incredible in-game. The grey washed up filter goes away. I looked at comparison videos with 4090 systems in HDR and it looks very similar (after applying the above settings from the guide). Anyway, 4k138hz OC 10bit Full RGB works fine in SDR and HDR for me over DP1.4 but with HDMI 2.1 I did notice some flickering issues and warnings saying my connection wasn't stable (and I'm using high quality Audioquest cables).
I suppose we'll have to wait for 4k240hz W/QD-OLED 16:9 monitors in the 32-42" range with proper HDR implementation and GSync Ultimate, that would certainly prove to be an upgrade. I almost want to get 2 of those new LG 27" 1440p240 OLEDs and return this but I hate the idea of having two separate displays and not taking full advantage of my 4090's capability to 4k120 most games.
Sorry to hear about your issues with the display. Which FW version are you running? Nice rig!
I had to change all my cables (DP and HDMI) to get rid of some of the issues. And I had Gsync enabled for windowed mode which caused flickering *facepalm*
I hope you get your remaining issues resolved.
I'm on the latest one (V033) installed properly via HDMI 2.1/USB-B as per the guide. I also had G-Sync enabled for both fullscreen and windowed at one point until I realized how dumb that was lol. I just want them to fix HDR in a way that doesn't require me to keep changing settings in the Nvidia control panel - it's an ok temporary "fix" but it doesn't address the real issue.
Maybe you could also post on the Asus forums? There is a link a few posts before yours. I plan to do the same.
Very sad situation with this monitor! Please fix the wakeup mode! The monitor does not wake up periodically after restarting the computer! The HDR mode is just disgusting! Firmware latest V33 It's a shame for such a price!
Yet another problem i've been facing for a while now with the v033 firmware is that g sync is completely unusable with 138hz, in previous versions it just used to spaz out in certain programs, but now if g sync is on even in fullscreen only mode, the monitor goes to black for a few seconds than back to normal again for a few seconds and the loop keeps repeating as long as i have an active window open, it's ok in desktop only. 120hz is fine, tho it did happen once to me specifically while i had ryzen master open. hdmi 2.1 that came with the monitor.
Also when i set nvidia control setings to 10 bit colour mode, in windows advanced display it states also 10 bit, so i know it's on. If i go to monitor overlay > system setup > information in 120 hz it states color depth as 10bit, but if i got to 138 hz overlay says 8 bit, even tho nvidia panel and winows is 10bit.
And what's up with their forum ? I've registered 20 hours ago and i'm still waiting for aproval to post anything, how is this normal?
can you set yours to 12 bit color. I can do it in the control panel. I have no idea if it does anything. I also keep mine at 120 hz thou.
Могу подтвердить, что мой 48UQ также говорит о 8 битах информации, а не о 10 битах, которые я установил в NVCP (138 Гц, V025 fw).
I have 8 bits on HDMI 2.1 at 138hz in the monitor menu, and in Windows it shows 10 or 12. In DP at 138hz 10 bits and there are no problems with Gsync. Some problematic monitor for a lot of money. V33pg42uq
У меня по HDMI 2.1 на 138hz в меню монитора 8 бит, а в винде показывает 10 или 12. В DP на 138hz 10 бит и с Gsync проблем нет. Какой-то проблемный монитор за большие деньги. V33 pg42uq
I don't speak/read good cyka, but are you saying your g sync, color bit rate is fine in 138hz while using a DP cable? How can this be, i thought that the DP does not have enough data bandwidth to even support 4k 120hz. Is anyone else having issues with g sync in 138hz with the HDMI??
I myself am surprised that with HDMI 2.1 at 138Hz it does not work in a 10 and 12 bit monitor and Gsync is not stable, but everything works stably on DP, except after restarting the computer, the monitor does not periodically wake up either on HDMI or on DP. Asus apparently cannot fix this and is delaying the release of the new firmware V34.
