My little occlusion specialists are doing their job perfectly!
This is amazeballs! All that work has come together! Super excited for the next sunny day!AC wiring at end of day 1
0.9kWh generated on the new panels.
It wasn't displaying battery % because it needed a full charge to calibrate it, it is now, it will also display time left.
Yes I need to setup home assistant, then get that to talk to the Victron system, then send it to PV Output, it will be done, but not just yet.
Will Victron be able to see it all?
Open advanced, go to widgets(top right of the screen) chose what widgets you want displayed for each individual component.
(it will give you the total widgets for each device to chose from)
That is where the real magic of the Victron VRM is![]()
If the above was directed to me I already have loads of widgets setup - you can take a look via the link below in my signature.
See what?
@Ron-ski .. so all in all what was the cost if i may ask ? how much saved on an installed system ? thx
Sorry I mean will it see your entire solar estate giving you one place to run pvoutput from for combined stats?
No, the real magic is in Node RedIf the above was directed to me I already have loads of widgets setup - you can take a look via the link below in my signature.
Here's the VRM with % remaining, and time to go, time to go is based on the last three minutes use, but you can alter that 3 minutes to what you want.
Here's something I've playing with in Node Red, Node Red uses Java script, which unfortunately I've never programmed with, so I need to learn it.
Well done mate what a great project you have installed. I myself was tinkering on the stats and node red, scripts, automations etc. so please share as you continue. One of my next gadgets is to ct measure the import only energy and get more or less a live, logged graphing.
