*** The Official Elite: Dangerous Thread ***
hopefully this fixes the bugged interceptor instances as well as stuck progress bar, both of which hugely had a negative impact on the game in open. This thargoid war has been the most fun i have had in the game in years.
Just started up, again! Decided to make use of my Tobii Eye tracker, and my flight stick. Them in combination with a HCS voicepack really adds a lot of immersion. I don't have VR, so this is probably the next best thing.
I've started playing a lot of No Man's Sky on the Switch, so felt the urge to check this out. Currently only running ship missions where I transfer data. Or, as my in progress mission says, go buy something. So I'm using eddb.io in search of the nearest and cheapest.
Very first run I did run out of fuel mid jump, and blew up my ship. Luckily it didn't cost anything to get it back. Since then I've had about 2 moments where I'm desperately low on fuel and just trying to survive to the next station available. Fingers crossed, everything is going as planned from now on.
I need to save up for a bigger / better ship. What should I buy? My main aim will be exploration and cargo missions.
Asp, Python or Krait Mk2 would be my choice, what are you flying now, the default Sidewinder?
I would check but seem to be having issues connecting. It worked fine last night, and now I can't even get to the main menu without seeing "failed to connect to authentication server". My Frontier account is connected to my Steam, the port is open and reachable, even turned off my AV and still same issue.
I can get on to Legacy Horizons but not Elite Dangerous: Horizons or Odyssey.
For starter trading, you can buy an adder or keelback, if you are on the sidey. Also try and take missions from only a single system/station. As your rep with the leading party at that station goes up, so does the money for those missions. Python is a good all round ship for trading, mining and combat -as recommended above. Also equip a fuel scoop if you can, will save you running out of fuel.
Thanks, I purchased an Adder. Just running transport missions and will try checking Inara database before jumping to my mission to see if I can transport anything for a profit.
I did notice the last base I visited, hadn't had any data update for 44 days, so didn't take a chance on that one.
Which app is most commonly used for helping to update the EDDN?
There are several.
EDMC (Elite Dangerous Market Connector) is a nice lightweight option. https://github.com/EDCD/EDMarketConnector/wiki.
I like EDDiscovery for the information it provides, but it can update EDDN as well. https://github.com/EDDiscovery/EDDiscovery
Both will also update several other sites e.g. Inara, ED Star Map and others, if you configure them to.
There's threads on most tools on the Frontier formums here: https://forums.frontier.co.uk/forums/elite-api-and-tools/
So I've finally figured out mining. I am currently tasked with mining 4 Hydrogen Peroxide, being my first mining mission I was pretty excited. Started out very confused on how to locate asteroids, so a search gave me the answer after a while. I visited a belt of asteroids and didn't see what I needed, so a quick search online found a nifty chart that told me to go to an icy area. Finally find some, pretty bad at scooping them up as they bounce all around my ship, and it seems I need to collect 100% to refine just 1 of these things. Now that's going to take ages to complete! So off to search again, learned about limpets, great I thought. First I bought a version that was incompatible. Next I buy the correct module and head out once again to mine some asteroids... I forgot something. Yes, got there and was confused why I couldn't send them out to work. So another search told me I have to purchase these limpets. Made the trip back to purchase.
Ended the night here, made numerous trips back and forth and now tomorrow I can maybe finally do some quick mining.
Oh and forgot at the beginning I didn't understand what PIP meant, so I was confused when I couldn't mine anymore as it wasn't charging. So must have spent half the night searching for answers.
you don't scoop the bits. you want to equip a prospector limpet controller and a few collector limpet controller. fill about half your hold with limpets before you head out. fire a prospect at an asteroid... if it's got valuable stuff launch your collector limpets then laser the rock. don't target the fragments your limpets do that.
not only does the prospector help find the best rocks to mine you get double the stuff from a rock whist has been prospected
if you can best mine from a ring with pristine reserves (levels show up after a detailed Scan or use inara 3rd party tool or similar
edit. I should have read whole post properly before wading in :D
Currently I have an Adder and just purchased the 8 slot cargo. That first mining mission was a disaster and I ran out of time. Currently doing another one now, jumped to a belt of asteroids, 4 sector's labled 1 through 4.
I did find the right material and I've now half completed my mission. Although now I'm stuck, it seems I've depleted the supply from these 4 areas (each one only contained a handful of asteroids), and now I've no idea where to find any more. I have no unknown sources in my navigation panel, and nothing there that points to another asteroid field I can identify.
And on the limpets you shoot at the asteroids, if each one takes up cargo space, I'd end up filling my cargo with just limpets for hitting asteroids and mining them. If they are one time use and I take one with me, then after hitting one asteroid, I'd then just have to mine the rest to find its contents?
Mining in such a small ship is probably not worth it.
You're obviously mining the small clusters of asteroids that show up in the navigation list and that are small clusters of a few rocks fairly close to the star, ignore them, I'd advise removing them from the list entirely. Find a planet that has rings around it and head into the ring, they are made of millions if not billions (possibly even trillions, I dunno, it's a lot though :) ) of ice or rocks to mine, you should be using a detailed surface scanner that will allow you to scan the entire ring and will then highlight hot spots of various materials so you can increase your chances of getting what you want, no harm in simply dropping into a ring and prospecting though, it just wont be anywhere near as efficient.
Other tips are:
Do not launch a collection limpet if you have a fragment targeted, it will collect that fragment and then destruct. Collector limpets that are launched without a target selected will simply collect any valid fragment or material until it expires.
Don't fly out of range of your limpets.
You can hide particular types of mined fragments from your contact list, which your limpets will then ignore so you wont end up getting frustrated at them picking up anything and everything which will quickly cause issues with smaller refineries due to the low bin count and you'll not waste time picking up low value stuff.
Try and mine asteroids from the point of centre spin (imagine the asteroid has a mail slot like a station and you are aiming at the slot) so fragments don't get thrown everywhere, it'll speed things up when collecting fragments.
Once you have depleted (full pips to weapons and mine as fast as possible) an asteroid position your ship so it is above the string of fragments, not too close to them, you'll get the idea after a few tries but ideally you want a string of fragments that you can position so they look like they are perpendicular to the cargo hatch (always on the bottom of the ship), it'll speed up limpet retrieval of fragments massively as they will only need to travel back and forth rather than around your ship.
Once your cargo is full you can continue to fill the refinery bins to 100%, they'll churn out the contents when you clear some cargo space.
i echo above. the type 6 is really the 1st affordable decent mining ship. and defo you want to mine in the rings around planets
the limpets are used up whilst mining so as you mine and your cargo goes up, your limpets will go down. you lose some space to the limpet controllers (which is why it's not really viable in an adder) but the prospector doubling your yeild of any scanned asteroid still makes it a no brainer.
you can get hybrid mining limpet controllers which cover prospectors and collectors. this may be better for a smaller mining ship like the t6
Thanks, I was able to locate what I needed in the rings. I love the scale of this game.
Just had another noob moment though. Took a job to supply the station with some goods, found a place two jumps away. They needed 20, I buy 20. Make the first jump but now I'm too heavy to make the second jump and got attacked by an Ai pirate.
After the battle, I looked through the menus for a solution, I saw I could jettison the cargo. So jettisoned 2, then another 2 and so on until I'm left with just 7 to deliver before I can make the jump. After delivery I jumped back to pick up the rest of my cargo but couldn't find it anywhere, then read online it dissappears when you jump.
So off back again I go, already lost about 74k worth of cargo at this point. Purchased the remaining 13 I needed and checked my galaxy map. Can't make it in 2 jumps, but an alternative route is possible with like 5-7 jumps. At one point in the journey back, got targeted again but this time managed to escape and continue my jump. Finally made it back safely and took my reward... I ended up taking a lot less money for better reputation as I read it's good way to get better paying jobs? So I think I might have lost money or atleast only earned got a small amount in my pocket, I can't remember my pay but was somewhere between 200-300k. Could have taken around 780k though if I took the full amount.
I couldn't easily see how much jump I will have if before buying the cargo, apparently it can be seen on the galaxy map to make sure you can make the jump but I couldn't work it out.
Going to try work up to buy the type 6 now.
yep the better the rep the better pay you get. my advice... if you are limited on cargo space and not specced to fight (though even a weak ship can kill steal in a RES) but i would say do the data trade missions as they do not take any space, and then mix in some black box recovery missions - (tho if you really dont want to fight be ready to run or read the description 1st).
the legal base scanning missions are also nice easy starter missions which pay ok.
I traded in the Adder for the Type-6 yesterday. This ship looks good when I disembark my ship.
Any recommended load outs? I swapped the pulse lasers for mining and drill. Not sure what I do with the drill though, just kept randomly shooting asteroids for fun.
So should I get attacked, not sure how I'm supposed to defend. When I first started mining with this ship last night, I had to divert a lot of power just to make the ship operational.
if you get attacked.......... run!.
make sure you have a rebuy just in case.
if you cant afford all the tools to mine properly stick some passenger cabins in and do some passenger missions - easy money and safe esp if you pick legal ones.
for now i would stick with mining lasers and ignore the abrasion blaster and explosives etc...... make sure you have a limpet controller for collectors and prospector (fit as many collectors as you can, you only need 1 prospector).
then got to a pristine metallic ring and fill your boots. dont forget to half fill your hold with limpets before you leave, and also pick the refinery with the most number of hoppers you can get within the slot size on your ship you want to fill.
Run forest forest run, just save up for a bigger ship for extra hard points and some gimbled whatever and the PVE ships shouldnt be a problem as such.
I am all thargoid out again so on another break, looking at a dedicated sim rig in the background as my first foray into racing games but also want it Elite/Star citizen and maybe everything else.
