Yes my Suprim X does that. Set the fan speed to about 55-58% and you’ll hear this weird metal vibrating sound and unless you ramp the fan speed higher it’ll keep doing it. @Hostile_18 checked and his Suprim X did the same too. If you ramp to 100% fan speed on the Suprim X you’ll hear it for a few seconds, once it passes 60% fan speed or so it stops.I exchanged my Suprim X as it had a rattling sound from the shroud.
PLease to report that the replacement has far less coil whine, it's definitely there but I need to go up to the pc case to hear it, whereas my previous one was audible from 2 metres away.
My only annoyance with the MSi card in general is the turbulence sound from the fans/air/heatsink, it's a really annoying ryhtmic sound.
It seems like all the 4090s have some sort of issue, be it rattling fans (Zotac), this issue (Suprim X), fan humming at low speeds (Palit), or coil whine (all of them), high temps (Gigabyte/Inno3d).
