*** AMD "Zen 4" thread (inc AM5/APU discussion) ***
Cheers
2 Months of stress
I hope he finds a fault on the CPU
My new board also has the debug LEDs , and there all off
The ASUS I had, the GPU fault light was always on, using pci GPU or on-board GPU, which makes me think it's the CPU that's faulty
And it struggled to POST a lot etc.
I watched a video and seemed like you had some of the same problems: issues:
I think I may have spoke to soon
Finished downloading project cars 2 on steam
Go to play, error
Check integrity, 100 files corrupted
BSOD irql not less equal
Restarted itself, BSOD on booting, different message...
Go to play, error
Is there anything you’ve not replaced at this stage? I’m assuming you are using the latest BIOS with the default BIOS settings including memory speed at 4800Mhz?
Did you get the same make and model motherboard as a second test motherboard to eliminate the motherboard as the issue?
Because if so, there's a danger it might have been hardware conflicts that were specific to those setups only, and thus why trying two new but identical motherboards may not have yielded anything different.
default bios at the moment
i will update that
I've replaced everything now lol
i think ill update bios, re install windows
shall i goto 11 or stick with 10 ?
see sig
then i replaced the motherboard for an identical one, same problem
now, im on MSI motherboard, with a different CPU and a Brand new SSD
