- 10 May 2004
- Sunny Stafford
Otherwise there is an app (came remember the name) that flashes a coloured ring around the front camera when a notification is received.
I like the idea of this as I did use the RGB LED notification light on earlier Galaxy models. For the coloured ring around the camera hole-cut out, will it eventually cause screen burn out in the area where the ring is if the ring is static? The always-on screensaver moves slightly every 1 minute to prevent screen burn out which is why it's called a screensaver.
