Nothing that weird, remember how the Pentium II was shaped?Ok, Maybe the PCB is longer than it needs to be but it is a weird shape...
Think old style console cartridge-like weird.I don't, was it really weird?![]()
Had to google it, wow that is weird LOL! Looks like a pci slot addon.Nothing that weird, remember how the Pentium II was shaped?
It was a weird era, in mid 1990s Intel bet on extra instructions to accelerate games (MMX), sadly those were rendered nearly useless by the arrival of dedicated graphic cards.Had to google it, wow that is weird LOL! Looks like a pci slot addon.
This is Raptorlake. the cluster i highlighted in red on the right are the 16 E cores, if you measure that you will see it takes up the same amount of space as nearly 6 P cores.
The die size is 260mm, its the biggest mainstream die Intel have ever made, this P and E core nonsense isn't winning it for them, to put that in to perspective the Logic die of a 7900XTX is 300mm, the 8 core Zen 4 CCD's measure 70mm each. the Zen 4 cores are little bigger than Intel's E cores.
It's interesting how you forgot the IOD for Zen or maybe found a magical way to make zen chips work without it.
7950x = 70+70+122 = 262
13900k/s = 257
Here's the "IOD" sections for intel laid out over the core.
The IO die is on a cheap node, it costs about $8
Why are you pivoting to cost? your post was purely looking at architecture.
Also, when did you learn about the buy price from TSMC for ccd's, IOD's, and internal cost of intel Fab BU to intel CCG BU?
Please link official info.
13th gen is good if you want performance on a reasonable budget.I feel like 14th gen and 15th gen for intel are going to be monstrous, every year the leap in performance seems to be very noteworthy and it keeps making me hold off from upgrading
Good DDR-4 with an i7-13770k is pretty close to the top performance at a reasonable cost and the main compromise you're making is basically the dead end socket (not an issue if you plan to keep the CPU for 5+ years).
Maybe not everyone wants the X3D chips that mostly only really benefit gaming, and are hit & miss there too.Intel need huge architectural and process advantages to be worth buying over Zen4X3D, I don't see how they can do all that by 14th gen. They'll be hard pressed to match Zen4 energy efficiency, yet alone beat it on performance at the same time.
Intel's only chance is Zen5 being late, or being another bulldozer, both of which seem very unlikely.
Hopefully they do compete though, can't have AMD with no competition for years, that's not good for the consumer.
How do you manage to come out with such rubbish, it obviously makes no difference which side you are on.
That's just nonsense. The zen 3d is a lot more efficient in gaming than the 13th gen, and a slight lead in heavy MT efficiency (at same power limits), but then it loses by a mile in everything that's mixed usage. Unless amd fixes the idle / low / mixed usage power draw it's never going to be an option for me. Intel draws 1.5w in idle and 8-15 watts while im actually working - while the 7950x or the 3d needs 30 to 50. The difference is absolutely nuts.Intel need huge architectural and process advantages to be worth buying over Zen4X3D, I don't see how they can do all that by 14th gen. They'll be hard pressed to match Zen4 energy efficiency, yet alone beat it on performance at the same time.
Intels 13th gen performance has been very competitive has it not? the top end is on par, if not beats the top end 4x3d chips and even the mid tier ones like the 13600 is very good bang for buckIntel need huge architectural and process advantages to be worth buying over Zen4X3D, I don't see how they can do all that by 14th gen. They'll be hard pressed to match Zen4 energy efficiency, yet alone beat it on performance at the same time.
