- 23 Mar 2023
- UK
it will be allot faster my tuned 6000mhz 2000fclk cl28 does 196fps with 7700x and 4090 with HUB settings. But you have 7950X3D so the difference might be smallerSince HUB use the Watchdogs legion benchmark sequence and I have a 4090, I can probably copy that to compare to HUBs numbers.
I'm expecting 6400Mhz C28 to be a bit faster than 6000Mhz C30.
EDIT, they also test Horizon Zero Dawn so could test that too.
sorry earlier message was meant to be sent to you.
