Using the RE Framework, only really enabled the ultrawide fix to enable vertical fix which expands the FOV to a better level so the camera isn't as closed in any more, the in-game FOV slider maxes out around 85 which still felt slightly cramped IMO so this sorts that out nicely. Also reduced the vignette amount massively which is much better now. Vignette should be a default option slider in settings.
.The only problem with the FOV tweak is that the case is now further back
