I’ve only played the first 90 mins or so but had a situation where I was downstairs and a bunch of AI were upstairs on a balcony in prime position but instead of using their height advantage they went full yolo and ran down the stairs toward me guns blazing.
Is AI intelligence effected by difficulty level or does that just effect their damage output ?
Finding it really strange... native res (1440p), I don't get much difference (in FPS) between medium/high settings, and again, it doesn't look like GPU is being fully utilised. My VRAM stays just a touch under 10GB on high @ 1440p. I'm finding 50-55 fps with drops into the 40's rather unplayable, especially with gsync on as the low refresh rate gives me headaches/motion sickness. Also feels stuttery and not smooth at all. I'm used to playing MW2 @ 140 fps/Hz with Gsync so 40-50 fps just feels awful for me... I'm not getting any crashes, even if I turn DLSS on.
What are those with 4090's seeing in terms of FPS @ 1440p on ultra?
P.S. Not sure if I'm on to something here, but regardless of what resolution/settings I play at, my CPU and GPU are only being 40-50% utilised maximum, and neither are getting anywhere near being hot... and no, I definitley haven't set a frame rate cap. I just followed a youtube video covering the best settings to improve FPS, and I'm still stuck at 50 fps with drops into the 40's...
A new hotfix for The Last of Us Part I is now live. This update addresses fixes that improve memory, performance, and more.
- Decreased PSO cache size to reduce memory requirements and minimize Out of Memory crashes
- Added additional diagnostics for developer tracking purposes
- Increased animation streaming memory to improve performance during gameplay and cinematics
- Fix for crash on boot relating to game save files
Guys disabling upscaling completely fixed stuttering for me.
I was running the game locked to 90fps before and still do and now even when it drops below that no stuttering occurs.
I guess I was wrong as stuttering returned lol.
Yeah mouse stutter is there for everyone I think.You obviously don't have enough vram![]()
My mouse needs more vram too as when using M+K, it's a stuttery mess but with the xbox controller, nice and smooth
New patch seems to be a slight improvement actually but I've only played it for 15 mins or so since installing it. Getting 60-65 fps on ultra using DLSS (Quality), which now seems to actually be doing something. GPU still nowhere near being fully utilised - doesn't go above 70%. I worked out the in game CPU monitor is broken, Hwinfo reports my CPU as ~40% utillised.
I would try getting rtss working and see what it says. You've got 2x6 cores right? Make sure it's using both sets. Maybe if there's config file move it somewhere and see if the game makes a new one, and see how you go
and 7900X shouldn't be limiting my relatively poorer spec 3080
I can't be bothered trying FSR again, DLSS is that good in this game![]()
