If you're going to try it then I'd get some diamond cutting discs.I only have a small handheld grinder - Milwaukee thing. Not big.
That is my best hand writing. I am literally some 'tard living a kind of slum dog millionaire life. As a boy, I never thought I'd own so many buckets, for a start.I see youve clearly marked your personal bucket there.
your lucky our bin men wont take the green bin if there is soil in it(i kid you not)Had a family day so only got a couple of hours in this evening. Managed to empty the green bin that had been overloaded with soil and weighed about 100kgs (10 buckets worth) and then hacked at the bush that was full of brambles. Maybe grab a few hydrangeas to whack here in this wet shaded spot.
(Haha, I emptied it manually becauseyour lucky our bin men wont take the green bin if there is soil in it(i kid you not)
they left it the other week because i had been weeding the front borders and there was soil on the weeds(
got my own back stuff some of it in the black bin .
I'm contemplating how to "demark" the borders versus the grass. Any thoughts? I tried the plastic edging stuff before, where it pegged onto the grass side - and the grass was intended to grow through it. Wasn't a big fan. Need to work progressively down this border.
Also - the ivy is wrapped around the mega holly tree. Is that an issue? Should I bin the ivy off?
It is hard to tell from the pics but the holly tree is like 12 inch circumference, so it is a mighty thing. The ivy is probably half inch thick dia.The ivy will eventually choke the tree. Cut the ivy a few feet off the ground all the way round the holly tree trunk then pull up the ivy from the roots below the cut.
Wait for the ivy to die off and dry up before trying to remove from the holly or you may cause damage to the tree. You may even get away with just leaving it on the tree if it's not hindering it's growth or looks bad
Thanks for the guidance. I've removed tonnes of the stuff as part of the fence project and this was the first area where I was thinking about leaving it. The roots are absolutely everywhere, the stuff is mental. I'll chop and remove roots as suggested (y).Yeah, but it will choke it and the roots of the ivy will damage the tree and bark.
Its vicious invasive stuff - we have a pair of really large trees in the back garden that I had to sort the ivy last year as the strands were absolutely everywhere.
I made the mistake of just yanking it off the wall at the side of the house and it brought the brick face off with it. So run the hedge trimmer along the face of the wall and let it die back before scraping off now.
It can grow / take over at an alarming rate
First cut of the year
That's a nice moss you have there!
Green is green.Ha ha it looks fine from the house, I've given up caring![]()
