An abomination to all of mankind.If the 7900XT is over priced, which i think we all agree it is, then what is the 4080?
With the way new RT games demand VRAM, surely after three generations of RTX the only the 3090 and 4090 and the 4080 can hope to run new games without actually running out.
Although, while the push for upscalers largely stems from the fact that with RT almost all cards come to a crawl (and if the RT is full path then even the 4090 needs upscaling), upscalers also require less VRAM. Well, yes, running at 720P does too!
Its why i don't get the obsession with RT for GPU's at anything below the 3090, its near useless for anything below that.
The number of games that in the ballpark of 0-5% difference swinging both ways are around the same in number (6 games on each side) in that review, so it evens out hence why I didn't see the point of of including them.So you just list all the games were the 7900XTX is faster and you remove all the others that is equal or slower?
The average from Techpowerup 4K Rasterization comparison 7900XTX vs 4080 show that the 7900XTX is 2% faster compared to 4080 (excluding RT) and to be honest reviewers like the Techpowerup should stop excluding RT from the average.
A 4080 can fit on midi tower no problem you don't need a full-size tower, in fact a 4080 is more suitable on a midi tower than the 7900XTX due to the lower heat output. Also the non reference designs have similar size regardless if it is 4080 or 7900XTX.
But then your card has an almost generous 12GB frame buffer and you are "only" on wide QHD!My 3080 Ti has played many RT games just fine![]()
But then your card has an almost generous 12GB frame buffer and you are "only" on wide QHD!![]()
Not as useless as most your posts. My 3080 Ti has played many RT games just fine![]()
Ray tracing is useless in general without upscaling from lower resolutions.
It generally cuts framerate in half, in all but a handful of games.
Why bother, lots of graphics cards need upscaling or frame gen to play at 4K resolution without RT.Of course it does, real time ray tracing is incredibly intensive hence why nvidia made DLSS in the first place. Thankfully the upscaling tech is so good (well for dlss anyway), no reason not to use it as proven by various review sites now.
A great cardwhat is the 4080?
They need to add the ability to lower the detail/ resolution of the ray traced parts of frames, which lots of games don't do, or do poorly.
It's not worth cutting framerates in half, especially when most graphics cards already struggle without RT on in demanding titles.
RDNA 3 is slower than ampere in RT. You won't see it on the averages cause averages include games with barely any RT effects. A 4080 is around 45 to 50% faster than XTX in RT horsepower.Given rdna 3 can sometimes perform worse than even a 3080 in RT, then rdna 3 must be doa for RT too.....![]()
Have I ever - ever - ever said that ada are aggressively priced? Nope. But I get it, when you don't like what is said but can't argue against it cause it's correct, you start the strawmans.Nvidia's soon to be launched $599 8GB GPU is going to be super aggressive alright, aggressively destroyed in reviews that is
A great card
Τhe normal XT? Over the 4080? Ohkay I guess?I'd sooner buy the 7900XT.
Going by history, you would likely end up getting the 4070, same way you bought the 970, 2070 over amds alternatives.......I'd sooner buy the 7900XT.
