- 9 May 2022
- London
Why did you not think about buying your own router and putting the vm hub in modem mode?
Also sounds like you need to be a bit more calm and polite, these people are only doing their job, they don’t need some irate person treating them like garbage.
Im usually very polite but prior to this I had already explained my entire situation to someone else who had said they would see what deals they could offer, had put me on hold for several minutes, came back and told me to call a different number which i called only for a recorded message to tell me the number was no longer in use and to call another number which ended up being the default virgin media support line meaning i had to go through the entire process again...
I was polite for pretty much the entire conversation right up until the point it became clear that i was talking to a brick wall who somehow hadn't realised that i don't have a superhub 4 despite me telling them i was on superhub 2 numerous times and who had even offered me an upgrade to a superhub 4 only a few minutes before (?!?!?). It really was baffling, like the conversation we had been having prior to that had never happened. I didn't actually tell them to 'koff' either, i mean that was the jist of it but it was worded a bit kinder
With regard to the router and using the hub in modem mode, i had done that over the years but at somepoint the router died and i just continued using the Superhub. End of the day it should work without buying a router, i shouldn't have to hard reset every day.
