So my parts arrived today, with a 7950X3D.Well this is disappointing.
I've just had notification that my order is shipping (from a competitor). The reason it's disappointing is that I think it'll contain the 7950X3D when I asked to swap it for the 7800X3D.
I know I should return it for a 7800X3D as I won't really benefit from the 7950X3D and it's over £250 cheaper.
But I've been waiting a while as it is and if I send it back I'll be waiting again...
Other than impatience there's no good reason to keep a 7950X3D over returning it for a 7800X3D is there, if gaming is largely all I plan to use it for?
Real men use a 7950X3D, so with that in mind should you really be using one? That’s the question only you can answer GM.So my parts arrived today, with a 7950X3D.
I dunno, feels like overcompensating...Real men use a 7950X3D, so with that in mind should you really be using one? That’s the question only you can answer GM.
It really did take all my strength not to get a 7950X3D, the fact it's got a higher number than 7800X3D was hard to overcome.Real men use a 7950X3D, so with that in mind should you really be using one? That’s the question only you can answer GM.
Will basically be the same, think 7800X3D is marginally faster on average.So my parts arrived today, with a 7950X3D.
For my Asus Strix B650E itx board, I couldn't load DOCP/EXPO for my Corsair 6400mhz RAM at all, it just insta-crashed/rebooted and sometimes Blue screened. I updated BIOS to the latest beta on the ASUS website, and then had to manually enable Memory Context restore which was in TWO separate areas in the ASUS bios (first is in AI Tweak header, the second is Advanced/AMD CBS/DDR Options/DDR Memory Features)BTW for those having RAM trouble using EXPO to post I found the following guide worked for me (basically manually inputting the EXPO settings in 3 steps)
Reddit - Dive into anything
www.reddit.com
If you were trying to run 6400 I'm not at all surprised it didn't work. The EXPO profile should be 6000Mhz at most. 6400 requires some effort to get stable and you need a sample that will accept that speed as not all will.For my Asus Strix B650E itx board, I couldn't load DOCP/EXPO for my Corsair 6400mhz RAM at all, it just insta-crashed/rebooted and sometimes Blue screened. I updated BIOS to the latest beta on the ASUS website, and then had to manually enable Memory Context restore which was in TWO separate areas in the ASUS bios (first is in AI Tweak header, the second is Advanced/AMD CBS/DDR Options/DDR Memory Features)
Since doing this I've got mine running at advertised speeds in EXPO 1, but admittedly, it's only been 1 day so far with some light gaming
Sorry I might have put down the wrong info - I just set the DOCP/Expo setting on my BIOS rated for the RAM I bought, which is 6400mhz (assume that's DOCP then?)If you were trying to run 6400 I'm not at all surprised it didn't work. The EXPO profile should be 6000Mhz at most. 6400 requires some effort to get stable and you need a sample that will accept that speed as not all will.
Yes the DOCP may well have been 6400Mhz but that's not meant for AM5.Sorry I might have put down the wrong info - I just set the DOCP/Expo setting on my BIOS rated for the RAM I bought, which is 6400mhz (assume that's DOCP then?)
OK then, I just ordered the Corsair 6400mhz RAM as my ASUS motherboard supposedly supports 6400mhz - although looking at the QVL list, mine isn't on thereYes the DOCP may well have been 6400Mhz but that's not meant for AM5.
Did you order it from OcuK?OK then, I just ordered the Corsair 6400mhz RAM as my ASUS motherboard supposedly supports 6400mhz - although looking at the QVL list, mine isn't on there
No - and now looking at it further, the kit I got is optimised for intelDid you order it from OcuK?
- rookie error that I didn't notice that (although it was hidden in the info and not in the header)It doesn't mean it won't work, it should still work. However you may have to adjust the frequency, timings and perhaps voltage yourself. The kit I suggested will be plug and play once you apply the EXPO profile.No - and now looking at it further, the kit I got is optimised for intel- rookie error that I didn't notice that (although it was hidden in the info and not in the header)
Thanks @LtMatt - I'll see if it stays stable, otherwise I'll look into the RAM you've linked - thanks for your helpIt doesn't mean it won't work, it should still work. However you may have to adjust the frequency, timings and perhaps voltage yourself. The kit I suggested will be plug and play once you apply the EXPO profile.
