Let me guess he is having it sprayed grey? Seems all the rage but got to keep up with the neighbours!
Yup was everywhere. Today the spray was everywhere must have being on someone else's property.
PlusGas or PBblaster ?
last plusgas I bought didn't have a long spray tube, (just small spray paint type nozzle) so it was difficult to apply to the bolts I wanted to remove,
without getting it on my hands, wasting product - is that typical ?
tried transplanting from other spray cans but nothing fitted.
My windscreen has come unbonded somewhat, typical Volvo thing.
Any ideas who can fix this back in place?
Otherwise I’ll probably end up putting a hammer through it and getting one on insurance.
@Frozennova I seem to recall you used to work with windscreens.
I got it done by National Windscreen for my C30.
It was like £120 to reseal or £160 for a completely new one in case it was smashed when they took it off. Cheaper than i expect. This was right at the start of the pandemic, prices may have risen since.
If you have water ingress from it, check under the floor.
Excellent, I’ll give them a bell, thanks.
Spoke to Autoglass, they wouldn’t reseal and a new windscreen without insurance was over £1000… lol!
No water ingress, yet.
"Intermittent water ingress" ftwNo water ingress, yet.
The two words that strike fear into the heart of any engineer: "Intermittent fault""Intermittent water ingress" ftw
Surely no more difficult than putting your registration into Eurocarparts, and verifying that the results (cca, Ah and physical dimensions) are comparable to whatever you currently have fitted?I changed the battery of my car. Spent more time finding the right battery than actually changing the battery![]()
