- 23 Mar 2023
- UK
Does anyone know what Core Performance Boost does in Asus bios and if it's worth enabling it while having PBO and CO enabled
Makes the CPU boost above the base clock frequency depending on thermal and power headroom. Auto = enabled and it's enabled by default.Does anyone know what Core Performance Boost does in Asus bios and if it's worth enabling it while having PBO and CO enabled
Morning!Leave that till then end once you have memory and curve optimiser sorted, then you can play around with it.
Most samples will do somewhere between 2067-2167Mhz. Higher is better but the biggest performance gains will come from the above rather than FCLK.
Stability test of Karhu with cache enabled running overnight is a good way to test FCLK (and memory) stability.
If FCLK is too high the system performance can drop (can verify using Aida64 latency/bandwidth or with Karhu hover your mouse over the % sign when testing stability) or the system may randomly restart. However, that can also be caused by too much curve optimiser on your best cores, so you need to take a methodical approach to tuning both.
I highly recommend Karhu for stability testing btw, its one of the best and well worth the small cost to buy to own. I use it more than TM5 these days.
Yeah it's not a huge deal but having it enabled adds a little bit of latency. People moan about longer boot times so you have memory context restore (MCR) enabled but that also means you need gear down mode (GDM) enabled on AMD which has a small latency cost.
That's why I keep MCR off and GDM off and put up with a ten second longer boot time and lower latency = better performance.![]()
really hmmm but my 7800x3d doesn't go above 5050mhz and it has enough headroom i think because it runs pretty coolMakes the CPU boost above the base clock frequency depending on thermal and power headroom. Auto = enabled and it's enabled by default.
WRWRSD needs to be 2.Morning!
I applied the timings and there's already an improvement as you can see. So that's awesome.
I couldn't find Gear Down Mode in the bios. Any idea what else it could be under or called?
Also, I'm not confident that I got the voltage info correct. Would you mind just having a quick glance to see all is ok?
I ran Karhu last night and after 22min it stopped with 1 error. I didn't know if I should just untick stop on error, but I'm guessing that any error is not good.
Thanks a million LtMatt. Much appreciated.
Base clock 4.2Ghz for the 7800X3D. So seeing up to 5050Mhz means CPB is working as expected.really hmmm but my 7800x3d doesn't go above 5050mhz and it has enough headroom i think because it runs pretty cool
WRWRSC needs to be 1.
SOC voltage drop to 1.25v - 1.3v in BIOS.
Enter DRAM menu scroll to the bottom and look for an option called CMD Mode and set to Buf. If the option does not exist your board doesn't have it I guess.
Bump DRAM voltage to 1.41v and VDDQ to 1.31v and retest.
EDIT - @01001101 See my edit above, you have a couple of timings wrong.
That's the one, disable it. Will need to verify stability with it off. Can always give VDD and VDDQ another bump to 1.42/1.32v as well if needed but it seems like you are not far off from stability currently.![]()
How's it looking?
I found CMD MODE - In this BIOS it's called ADDR_CMD_MODE.
Is there like a memory guide for dummies? I would love to know what all of these memory names and settings actually mean. It's a whole other language.![]()
Alright. Cool. I've got to pop out for a bit so I'll let Karhu do it's thing for a while and then seeing how things go I'll let it run over night again as suggested.That's the one, disable it. Will need to verify stability with it off. Can always give VDD and VDDQ another bump to 1.42/1.32v as well if needed but it seems like you are not far off from stability currently.
It's fascinating. I need to take the time to better understand what's going on.Sadly no, I wish there was. I am still learning myself. It seems like there are some JDEC DDR5 rules which neither AMD or Intel follow correctly from what I understand, so the best values for some of the timings is still an open subject. Lower is not always better as some timings depend on others and can break if too low.
I changed my mind again and I'm back to the NR200P (at least for now)Quite nice choices. I'd go with it.
Hey bud, Just got home.That's the one, disable it. Will need to verify stability with it off. Can always give VDD and VDDQ another bump to 1.42/1.32v as well if needed but it seems like you are not far off from stability currently.
Try putting tCL up to 32 from 30, see if the DIMMs are just a bad bin and rerun the test.Hey bud, Just got home.
What do you reckon?
Just installed my new 7950x3d. Put my Ram timings back in, checked aida and latency is up to 60. Was getting around 56 with my 7700x. Is there more latency with the 3d chips ?Try putting tCL up to 32 from 30, see if the DIMMs are just a bad bin and rerun the test.
Yes, approximately 4ns.Just installed my new 7950x3d. Put my Ram timings back in, checked aida and latency is up to 60. Was getting around 56 with my 7700x. Is there more latency with the 3d chips ?
I am idling at 25c.
AIOs look really cool. I just heard that they could be noisy. Your temps seem fine, no? That seems to be roughly what most people are reporting. I’m using a Noctua air cooler in a Phanteks case with three intake fans and an exhaust, no undervolting. Not sure why I’m idling 10c-15c lower than others. Sensor problem?I'm idling at 38-40c with an AIO. Totally overkill cooling but it looks cool.
Might be down to what he has installed/running, but mine are similarly low on an aircooler (don't think the cooler is the bit making the difference more likely cpu usage tbh).AIOs look really cool. I just heard that they could be noisy. Your temps seem fine, no? That seems to be roughly what most people are reporting. I’m using a Noctua air cooler in a Phanteks case with three intake fans and an exhaust, no undervolting. Not sure why I’m idling 10c-15c lower than others. Sensor problem?
Ok cool, good to know. Cheers.Yes, approximately 4ns.
