Yep it’s XMP profile.Are you still running it at 6000 CL30? in that a manual tune or just EXPO?
Maybe they are not the same but XMP profiles do work on AMD motherboards at least on asus motherboards. My memory is XMP not EXPO...EXPO, XMP is Intel, i often use them interchangeably myself and should really stop, they are not the same thing.
Drop it down to the next lower level, see how that goes, when you do make sure your motherboard doesn't revert back to pumping it full of volts again.
Same here lol l. Just upgraded a 2011 socket with a 3930Probably, I have no idea this is all new to me, my last build before this one was 2011 I think.
But having over researched watching lots of reviews I not once did I come across anyone saying running ram at advertised speed will likely void your warranty. So it's either such common knowledge that nobody bothers to mention it or tucked away in the small print.
Highly doubt it, I’m running 1.154v SOC, VDDIO, at 6200MhzC28. The instability will be related to DRAM timings or insufficient voltages.They were working before but I’m back to XMP profile with lower Soc voltage. Seems 1.25v isn’t enough to for XMP be stable.
Matt I’ve not had a single crash for a months until I lowered Soc voltage. Now it happens every day.Highly doubt it, I’m running 1.154v SOC, VDDIO, at 6200MhzC28. The instability will be related to DRAM timings or insufficient voltages.
You've got an Asus board right? So that's what you THINK you're running...Highly doubt it, I’m running 1.154v SOC, VDDIO, at 6200MhzC28. The instability will be related to DRAM timings or insufficient voltages.
May well be closer to 1.2v tbf as it’s Asus.You've got an Asus board right? So that's what you THINK you're running...![]()
I knew you didn’t properly test stability.Matt I’ve not had a single crash for a months until I lowered Soc voltage. Now it happens every day.
I don't know, if it's XMP I doubt it.@LtMatt does his RAM not have EXPO?
No I didn’t as I test my system by using it the way I normally do.May well be closer to 1.2v tbf as it’s Asus.
I knew you didn’t properly test stability.![]()
If you are asking about my ram then no it doesn’t have EXPO.@LtMatt does his RAM not have EXPO?
So, had my 7950x3d rig powered down for around a week or so, while I waited for the dust to settle. Inspected the CPU/socket, no signs of damage, even when tilting at angles under light as per
I had probably around 30 hours gaming on the system in total, as was only using for games and had my 13900k system for work/VR.
Updated my x670e Hero to v1401 today. SOC voltage before (was on V1002 bios) was 1.354v. After update to v1401, it's 1.252. Both were using EXPO on my Corsair 32GB 6000Mhz C30 kit.
Now it's time to go back to gaming, with maximum frame rates at crazy low power levels.
Ok....If you are asking about my ram then no it doesn’t have EXPO.
It is the cheapest 6000 cl30 ram here on ocuk that you can buy and it’s made for Intel CPUs.![]()
It would be long dead before it would show any physical damage.
Oh didn’t know about that.Nope, many reports on reddit of signs of heat damage before CPU failure. RMA's were accepted for working CPU's for these people.
If you are not going to test for stability, does it even matter ?What do you recommend I set that to and can in improve ram stability.?
Will look at mine in a minute then.
@LtMatt ok I got to a save point in Jedi and was able to reboot th system, the option is called cpu vddio /mc voltage.
